Newbie questions - Please be gentle...
So I am looking into a ralliart as a DD... I have an 03.5 M3 now and I don't have a warranty and while I love the car, the maintenance is expensive and If something were to break thats costly I'd be able to pay for it but rather annoyed.
I'd love an EVO MR but they're simply not inexpensive enough for me to consider yet.
I'd like a Ralliart but I have some questions... If you guys can answer them I'd be grateful.
1- Is there user-programmable tuning (ie I tune the car not a tuner) available? IF so, where from and how much?
2- I know the transmission on the MR and the Ralliart is the same and it doesn't support as much power as the manual transmissions - How much power are people making on these cars? Is 300-350awhp possible?
3- Are coilovers readily available?
4- How wide can you go with tires without issue?
Thanks guys!
Thanks guys!
Thanks - Cost?
So that implies there's a clutch upgrade, yes?
Where would I look for that
Will do!
Thanks
Will do!
Thanks
1) ~$25 for EvoScan and ~$170 for Tactrix OpenPort2.0 (+~$300 for a netbook, if you don't have a laptop already)
2) Yes, clutch and transmission upgrades are available. SSP Clutch pack ups power handling to ~400HP&torque. You'll want to add a transmission cooler to it, too.
it's here:
http://www.worksevo.com/store/produc...oducts_id=1057
and other transmission upgrade parts:
http://www.worksevo.com/store/index....th=100_104_123
it's here:
Awesome info! So then on stock setup you can see 300-350whp ? at the 400whp mark you need to upgrade? or are you needing to upgrade at 300whp?
2. if you do upgrade the turbo you just need to keep that torque under 300
If i were you i would get the clutches and tranny cooler before blowing it up. then look into either a fp red or fp black turbo upgrade. might as well go big if your upgrading your clutches otherwise stick with a evo x turbo and tune it to 300whp and 300wtq and you will be on the safe side.
Common mods are catback exhaust, test pipe, drop in filter, intercooler piping, FMIC, boost pill, lowering springs (there are some coilovers; tein & BC), new tires (get those ASAP) and now the X turbo swap.
245/40/18s can fit with little to no rolling if you get the right offset wheel. I know I can get 255s on it and maybe even 265s with the right offset and massaging of the fenders.
kyoo
618
Jul 27, 2022 11:38 AM
