evo x dual exhaust on ralliart?
Old Nov 12, 2010, 11:15 AM
  #31
Mike W's Avatar
I have seen two RalliArts running EVO X aftermarket exhausts. Both posted up on forums that it fits and rawk on!
In person, one had a melted bumper (the X tips are shorter) and the other was rattling something fierce beating on the control arms with the bumper about to melt. They dont fit.
Mike W
Old Nov 12, 2010, 01:40 PM
  #32
sstevojr's Avatar
oh wow, I was afraid of something like that. Thanks.
Old Apr 8, 2012, 07:09 PM
  #33
Conway_160's Avatar
Well im glad i found this, i was going to get an exhaust for my 2011 Ralliart but it was going to be off of an evo. This saved me alot of money thank you guys!
Old May 8, 2014, 04:16 PM
  #34
Ozeki211's Avatar
If you use a evo x exhaust pipe that goes from the middle exhaust out to the rear then it should fit, you just can't switch mufflers cause the end piece is different the only thing that might cause rubble is the back chassis so you might have to lower the exhaust muffler I don't know yet I just bought the tomei titanium exhaust for my ralliart it's made for evo x but I called tomei and the guy said it should fit. I'll keep you guys posted it sucks that there's no single exhaust system for the ralliart. I looked at Google images from the evo x and ralliart it looks like it should fit. In theory it should since we have the same differential (I'm not saying same system) from the center to the back route for the exhaust should be the same if the pipes are the same width. They should be since they are both running turbos. This is just a logical analysis.
Old May 9, 2014, 07:55 AM
  #35
neogeo64's Avatar
Dig this up from the grave
I think the problem was the cutouts in the bumper are spaced different.
Old May 9, 2014, 05:44 PM
  #36
02ES=>09RAL's Avatar
The Tomei has been used before.
http://www.clubralliart.com/showthread.php?t=462
The Tomei will bolt up, but it's not a perfect fit.
From the person that installed it.
Originally Posted by Blaze
It has similar connection points to that of the evo. I found toward the end that I have 3 issues with the install.
1) On the Sportback RA, the muffler tip sits inside the bumper, thus a heat shield will be needed for prolonged use. I'm sure I can find one on line for 50 bux.
2) The exhaust hanger near the rear axle is in a different location on the RA and Evo. The exhaust sits pretty snug now, but I'll make a bracket later for added support.
3) The rear bolt on a rear tie bar was dangerously too close to the exhaust piping. I removed this and life was good. Later I'll make a similar mod that RMR does with their evo 8 downpipes. That or I'll use a flush bolt.
Might burn your bumper :P
Old May 10, 2014, 12:43 PM
  #37
Ozeki211's Avatar
I have a ralliart sedan isn't the hatch back a little bit longer ?
Old May 11, 2014, 12:41 AM
  #38
neogeo64's Avatar
yeah the bumper sticks out about 2" farther then the sedan.
Old May 11, 2014, 09:33 AM
  #39
Ozeki211's Avatar
So it should fit perfectly with the sedan? If not I have a solution extend it with 304 stainless steel probably going to have to weld it
Old May 11, 2014, 10:12 AM
  #40
Old May 23, 2014, 07:03 AM
  #41
jermz1's Avatar
Ive just aquired both oem evo x mid pipe and exhuast.ill see if it works.
Old Jul 2, 2014, 07:16 PM
  #42
Ozeki211's Avatar
Up date for the tomei exhsust
I was able to extend it by getting another piece of titanium from titanium joe it costed about $60 for shipping included I had my muffler shop expand the titanium so it will fit
Old Jul 2, 2014, 07:21 PM
  #43
Ozeki211's Avatar
More pics for the tomei exhaust
Here are some pics that I have taken after my muffler shop expanded the titanium piece
Old Jul 3, 2014, 10:37 PM
  #44
Ozeki211's Avatar
Update change of plans
Decided to extend it from the middle out instead of by the muffler by extending it from the middle out I won't hit the chassis and tie bar thanks too neogeo64
Old Jul 22, 2014, 11:28 PM
  #45
DAN123AC's Avatar
I have a TurboXS full 3 inch turbo back exhaust . Made for the EvoX and listed for the EVO. I put this on my Ralliart . I bought it and everything fits flawlessly like a glove. Has single muffler with dual 4 inch tips exits. Bolted right up stock locations and zero fittment issues .
Quick Reply: evo x dual exhaust on ralliart?
