93 octane tune and using 91 octane is it bad?
Old Oct 8, 2010 | 09:19 AM
Rocky_RA's Avatar
Question 93 octane tune and using 91 octane is it bad?
What can happen if I have a 93 octane tune on my car and I put in 91 octane?
Can something bad happen?
Old Oct 8, 2010 | 09:29 AM
nunyas's Avatar
you could, in theory, get ping/knock, depending on how aggressive the timing is for the 93 tune. Ping/Knock = the air fuel mix detonating prior to the spark plugs sparking = bad. Potential blown engine if the ping/knock is bad enough
Old Oct 8, 2010 | 09:40 AM
Rocky_RA's Avatar
so is it that bad? I've only had it for 1 day. I thought the octane at shell in my area was 93 octane... turns out it's 91 sooo I'm not freaking out ... but almost...
Old Oct 8, 2010 | 09:42 AM
nunyas's Avatar
knock is bad
If you hear knocking on the tune, flash to the 91 tune asap...
some might say flash to the 91 tune anyway just in case
Old Oct 8, 2010 | 09:45 AM
Rocky_RA's Avatar
I will has soon as I can, in the mean time I wont go WOT!
Old Oct 8, 2010 | 11:28 AM
Rocky_RA's Avatar
Can my engine blow up????
Old Oct 8, 2010 | 11:36 AM
jkennedy293's Avatar
Originally Posted by Rocky_RA
Can I blow my engine????
Yep, but you probably should turn it on first!
Old Oct 8, 2010 | 03:57 PM
Piper747's Avatar
go get gas from husky in the meanwhile. They have 94 with ethanol. That will tie you over.
Old Oct 8, 2010 | 06:58 PM
zx-319's Avatar
As I told you over the phone, drive slowly, don't push the car and come have flashed with GST v2 for 91 octane!
Usually, if you get a significant amount of knock, you engine will switch to a low octane fuel map BEFORE you blow your engine... You can still do significant damage if you constantly drive under full throttle but if you stay out of boost you should not have trouble.
Old Oct 9, 2010 | 05:26 AM
Rocky_RA's Avatar
I went to sonoco yesterday to fill up half a tank of 94 oct. I will stay with the 93 tune, add octane booster the next time I fuel up and just fill up with 94 all the time I wont go WOT until I can.
Thanks guys and fyi the car is running great, it even starts better then before and fuel economy has gone up quite a bit
Old Oct 9, 2010 | 06:15 AM
Slee256's Avatar
Why would you add octane booster if you're going to start using 94 octane from now on?
Old Oct 9, 2010 | 06:50 AM
Rocky_RA's Avatar
I'm going to put some octane booster because I'm sure there is some 91 octane left in the tank. I fueled up with half a tank of 91 left yesterday.
To make it short I want to be on the safe side
Harsh476
Jan 9, 2016 09:58 AM
blackoutVIII
May 24, 2013 02:57 AM
icole
Apr 2, 2009 04:59 AM
vegasevo9
Aug 23, 2008 06:46 PM
mybada
Jun 29, 2007 12:40 PM
Quick Reply: 93 octane tune and using 91 octane is it bad?
