UR Exhaust defeat drone?
Old Nov 2, 2010 | 11:17 PM
jRox's Avatar
Hey guys. I've had the UR Axleback for a couple months now and I'm quite satisfied. The aggressive, deep tone sounds great and although it's a little on the loud side, I don't mind it. At highway speeds (60mph-75mph) while in the driver seat, the drone is bearable and almost unnoticeable with music on. However, I recently sat in the rear seat and realized how intolerable the drone is for passengers--to the point where I can't have a conversation with those in the front without yelling.
I know there are plenty of guys running the UR exhaust whether it be the turboback, catback, or just the exhaust alone. Just looking for some insight whether you experience drone on the highway (60mph-75mph). If not, how did you defeat the drone? And what setup are you using?
I was thinking about upgrading to the full turboback as well. Of course with all cabin noise reduction possible: Downpipe, HFC (to pass inspection), and both mini-muffler & resonator in the mid-pipe section.
Would upgrading the stock pipes only make the drone worse (even with the resonator & mini-muffler)? If so, I'll just leave it as is or look for a less droning exhaust.
Thanks in advance!
Old Nov 3, 2010 | 12:12 AM
Rocky_RA's Avatar
You can put alot of dynamat (or what ever it's called) to help lower the noise inside the cabin.
Old Nov 3, 2010 | 07:06 AM
03chi-town0Z's Avatar
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
Old Nov 3, 2010 | 09:03 AM
maackin's Avatar
slap a mini muffler from vibrant on the midpipe it did wonders for me.
Old Nov 3, 2010 | 06:42 PM
E46byeRAhi's Avatar
i have the ur catback with the midpipe resonator and its been good to be. i had a cabin rattle at low rpms but i checked under and realized the thickness of the midpipe was hitting the exhaust shield under the car. i shifted the midpipe to the left about a half inch and all was good. no more interior rattle and much less 'drone'. at highway speeds, much quiter than my e46 with oem cat+resonator+straightpipe muffler delete. i do plan on dynamatting the trunk first since its so easily accessible + for passengers. if you go any louder with your system, dont expect the drone to decrease... dynamat is your answer
Old Nov 4, 2010 | 12:20 PM
maackin's Avatar
bottle type resonator are not as good as the mini muffler type resonator just to let you know.
Old Nov 4, 2010 | 01:49 PM
blaze_125's Avatar
Save the conversation for when you get to destination?
Old Nov 4, 2010 | 02:08 PM
Westbound&down's Avatar
the exhaust is loud in your back seat? no waiii.
Its the price to play.
Old Nov 5, 2010 | 06:40 AM
blaze_125's Avatar
When conversations are a must!
Old Nov 5, 2010 | 08:58 AM
nunyas's Avatar
sound clip(s)?
Old Nov 8, 2010 | 10:27 PM
jRox's Avatar
Thanks for the input guys. I did look into sound deadening, but the for the cost, the results are minimal. I guess I'll just tough this one out.
Old Nov 13, 2010 | 04:43 PM
MichaelRalliart's Avatar
Registered User
I have an Ultimate Racing catback exhaust and it rattles like crazy right below the shifter and i looked under the car and the midpipe is like hugging the side of the car next to the heatshield, how would i fix that, it is unbearably annoying, and the exhaust is mounted in the right spot.
Old Nov 13, 2010 | 04:52 PM
DaJackson's Avatar
I had the same issue so I had the installer wrap the pipe to provide some cushion. But it still happens a little.
Old Nov 25, 2010 | 04:58 PM
Runaround's Avatar
I have the UR catback w/ the mini-muffler on the rear mid-pipe. I still have a lot of drone at 75ish. I'm thinking I'll try adding the front mid-pipe w/ the resonator to quite it down a bit and hopefully remove the drone.
For the people that the have the front mid-pipe hitting the side fo the heat shield, unbolt the pipe and rotate it 180 deg on the long axxys. The connection plates are slightly at an angle and if it's on backwards it will pull the exhaust out of center.
I have to say that overall I'm not that satisfied with the UR exhaust. It doesn't fit well to the HFC pipe from them or the stock cat pipe. It sounds good at high RPM but in the range the car is in most of the time it's very boomy and drones badly.
Old Nov 25, 2010 | 05:14 PM
Slee256's Avatar
I agree. I had good results with the Vibrant Ultra Quiet Resonator myself. Weld it into the midpipe as close to the Cat as possible.
Quick Reply: UR Exhaust defeat drone?
