what's needed to get a 300whp ralliart
i know of replacing the the ralliart turbo with the evo x turbo, is there another type of turbo that i can replace the ralliart one directly with, without having to change all of the oil feed lines? and what manifold would you guys recommend?
To the OP:
More than likely you are going to need to change out your oil and coolant lines. This isn't a big deal, you are disconnecting them anyways when you swap out the turbo. If you go X turbo route you will need an X manifold. Do a quick search and there is a whole thread with every part required to do the X swap. It seems most people here with the X swap and bolt ons are putting down hp and tq in the 300-325 range. This leaves for a very reliable but yet much more fun RA.
KnucklesVIII
Jan 14, 2017 07:55 PM
