need some advice with my set up
well the day before thanksgiving i blew my freaking engine... now i have a new block and oem crankshaft.... i decided to build my motor.. so i just bought the following parts just in time for all the amazing deals for the holidays lol..
cp pistons
manley h beam rods
acl bearings
arp main studs and head studs
brian crower stage 3 cams,spring/retainers,ss valves
ssp light weight flywheel
and im about to purchase the ssp 500hp clutch paks... from my homie mike at awd motorsports..
well my question is... should i stay with the stock evo x turbo setup...
or can i put a bigger turbo and wat you reccomend with my new setup?
i already had
255 wallbro fp
rewire kit
3inch exhaust
intake
fmic piping and ic
grimm speed mbc
900 cc fic injectors
and i want to go e85
cp pistons
manley h beam rods
acl bearings
i already had
255 wallbro fp
rewire kit
3inch exhaust
intake
fmic piping and ic
grimm speed mbc
fp green is going to be your best bet. The red is cute but for a fun quick spooling car the green wins out every time. An alternative that spools nicely is the bbx lite. Very similar results, both great quality. Its a toss up really.
Its fair to say most of this is over kill, but i understand you wanting to experiment and explore so gl with the build
The main thing i would change is the 500 clutch pack down to the 400.
If you tune it at AWD on a bigger turbo i doubt you'll need the MBC.
If you dont already have one, an upgraded BPV would be a great idea. Agency Power makes a sick unit at a good cost.
And for the heck of it, get a nice manifold o2 housing setup while your putting it all together. Not sure what the overall satisfaction is on the Megan racing pieces, but i believe map makes a nice setup as well.
Lastly, you dont mention which IC you have, but a stock EvoX cooler probably wont cut it. Id look to AMS UR ETS or others for a larger 3.5" + solution.
thanks bro.. i forgot to mention.. i do have a tial qr bov...and i have an ets frount mount.. i agree with map manifold.. and a 02 housing.. well im kinda stuck with the 500 hp clutch pak.. its already shipped and on its way... so overall the fp green is were its at huh? ill take a look at one.. and see wat ill do...
i mustt of hit the rev limiter... im not really 100% sure wat happen.. all i know my rod went thro my oilpan... and a piece of my block were a ground wire was bolted on blew off..
