Is this the correct output of power that I should be getting??
So the tune is causing it to slip?, cause its noticeable when I press the pedal down 50% and hold it in 3rd gear then go in to 4th u hear the trans blow and all power shuts down.. that's when it goes into limp mode.
Either way, I understand your frustration at bad information being posted. I didn't mean to stir the ****, so to speak. I didn't realize that you could leave it on, depending on the dyno.
Thanks for yoit helps guys I'm going too another rep turner garage who works specifically with mitsus and evos, and letting him check out the tune and see what's wrong with it.... I should of gone to him in the first place, but didn't know about him till now... not too many import tunes here in Houston.Tx
