Bypass Valve 1507A009
Old Jan 14, 2011 | 04:32 PM
robearralliart's Avatar
I ordered an EVO X (09 to be exact) OEM Bypass Valve and recieved a plastic one exactly like on my 2010 RA Sportback
OEM Part # 1507A009
I cannot find anything about this part #.
Does anybody know the OEM part # for the metal bypass valve for the EVO X?
Old Jan 14, 2011 | 04:45 PM
jkennedy293's Avatar
Check the for sale section. I'm sure someone is selling one, and for alot cheaper than the dealer.
Old Jan 14, 2011 | 05:53 PM
Mike W's Avatar
You would want 1545A001for the metal BOV.
1507A009 is the plastic one.
Mike W
Old Jan 14, 2011 | 06:58 PM
Mike W
TY Mike!! +1
Old Jan 14, 2011 | 09:14 PM
Skym's Avatar
How much is the metal bpv from the dealer??
Old Jan 14, 2011 | 11:01 PM
Mike W's Avatar
Maybe some leak more than others. I put the plastic BOV from a customer's RalliArt on a tuned EVO X and it really didnt make much difference. Maybe the EVO X turbo just powered right through it as the EVO X error correction dealt with the leak.
Then I put an EVO X metal BOV on my tuned RalliArt with a stock RalliArt turbo. It made a big difference.
Purple and blue runs were the stock RA plastic BOV and the red and green runs are with the factory metal BOV. The difference in boost was worth about 10 whp.
Mike W
Old Jan 14, 2011 | 11:28 PM
RideSober's Avatar
Thanks for posting that data Mike. Amazing that the plastic OEM BOV makes almost no difference on the EVO X but has such a negative impact on the RA.
Who would have thunk it
A compelling argument for those who may have been sitting on the fence regarding a replacement BOV. I know the EVO X BOV I recently purchased should be here in the next couple of days.
Old Jan 15, 2011 | 01:27 PM
Mike W's Avatar
Yeah, I looked at the two BOVs. Both had a rubber o-ring on the valve. Both had the same spring pressure. Ran the test on the tuned EVO X and declared that there was no reason to switch it out. Figured that if anything would make it leak it would be a big bad X. Thought about it a little and then tried the test back the other way on a RA. OOps :-P
Mike W
chase383
Dec 28, 2016 03:28 PM
Tekniq
Jun 14, 2016 08:35 AM
BooHAHA
Apr 28, 2013 11:01 AM
jc7651
Jan 6, 2005 02:10 PM
Quick Reply: Bypass Valve 1507A009
