How to check CEL with tatrix and evoscan?
Old Jan 19, 2011 | 04:21 PM
S2K2EVO's Avatar
Please tell me how to check the service engine soon code that just popped up. Hopefully it just has to do with the cold and the GST tune. The car doesn't drive any different.
Thanks
Old Jan 19, 2011 | 04:45 PM
S2K2EVO's Avatar
I plug everything in hit check DTC codes and it says cannot read ECU?
Old Jan 19, 2011 | 04:55 PM
jkennedy293's Avatar
change "select DTC method" to EVOX EFI
change "select ECU: to Mode23 USA EVOX
Check the Openport 2.0 box and the CAN 2006+ box
I ran into the same problem the first time and just started trying different drop-downs until it worked
Old Jan 19, 2011 | 05:37 PM
S2K2EVO's Avatar
Thanks for the reply!
Old Jan 19, 2011 | 06:40 PM
No problem
Old Jan 19, 2011 | 09:43 PM
sstevojr's Avatar
Select EVOX SST for....the SST
Old Jan 20, 2011 | 12:46 PM
stfuad's Avatar
OT: You know what i found out today? On a 1999 dodge intrepid you can do a Key on, key off, key on key off, key on. The freakin mileage display will show you any DTCs you have. Why isn't this standard on all cars?
Old Jan 20, 2011 | 01:19 PM
SiliconTek's Avatar
So products like this can be sold for ~$400...to the village idiots.
Old Jan 20, 2011 | 03:34 PM
Slee256's Avatar
I got one of these http://www.scangauge.com/products/ and I LOVE it!!! It cost less than $200 and I have it mounted on my dashboard above the steering column and it gives me digital readouts of MPH, RPM, A/F ratios, Manifold Absolute Pressue(MAP), coolant temperature, and about ten other display options. Not only that, but here's the best part. It has a:
BUILT-IN SCAN TOOL!!!
The ScanGuageII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
Old Jan 20, 2011 | 06:57 PM
S2K2EVO's Avatar
Slee that sounds like a nice scan tool you got. I just hope the light stays off now. I know Bryan said he was going to look into the cold start CEL. I love the tune and don't want to have to go back to stock and get rid of the GST pill as well.
Old Jan 23, 2011 | 02:33 PM
stfuad's Avatar
That is ridiculous.
OTOH I paid $2k for a SnapOn Solus that needs to be updated again.
Old Jan 24, 2011 | 03:26 PM
S2K2EVO's Avatar
Had to use this again today. It read the code and cleared it perfectly. Thanks again for the help!
Old Mar 7, 2011 | 06:38 PM
BravoZero's Avatar
I just got Evoscan and I can't get the damn thing to read anything on my car. Using v2.7.0090, have "CAN2006+/EvoX" and "Openport 2.0" checked, selected "Mode23 USA RA EVOX", and it acts like it connects but says "Cant read ECU ID" or something like that.
Old Mar 7, 2011 | 08:24 PM
S2K2EVO's Avatar
I followed the directions above. It worked perfect! I would check your settings and then try again.
It was just a cold start CEL related to the GST. Thanks to GST they released the V2.5 that got rid of it for good in the cold weather.
Old Mar 7, 2011 | 11:59 PM
gloom's Avatar
Looks like a solid product but the 80's called and wants the screen back
Quick Reply: How to check CEL with tatrix and evoscan?
