meth or 85
Old Mar 10, 2011, 10:14 AM
vplukas101's Avatar
Originally Posted by tscompusa
yes thats what i said.. uses 30% more fuel then regular straight gasoline due to the high ethanol content.
i get that but if i change it for 85 to 93 wont it use more 93 because of the injector size?
Old Mar 10, 2011, 10:16 AM
surferjeff's Avatar
Both make power. running fuel through the fuel injectors is the best way to get equal distribution.
Old Mar 10, 2011, 10:58 AM
tscompusa2's Avatar
no.. reason being is alt maps have their own injector size scaling. you have two separate values for each map to control the injectors and keep the fuel trims under control.
Old Mar 11, 2011, 10:04 AM
toredefine's Avatar
Don't do Meth: https://www.evolutionm.net/forums/ev...o-cracked.html
E85 can be ideal, but you also risk that on some occassions, the pump will not give you true E85. Sometimes it can be less, and you put your car in danger.
I don't run either on my car. I'll stick with pump gas for a while. There are lots of information on both. Let us know what you end up doing.
Old Mar 11, 2011, 10:52 AM
tscompusa2's Avatar
if you're tuned on e85 and get e70 you will run a bit richer.. no big deal.
if you're tuned on e70 and get e85 you will run a bit leaner.. no big deal.
e85 can run really rich or really lean its RBT and LBT are very high compared to regular gasoline which usually only has around 10% ethanol content maximum.
As long as the tune is not dangerously on the edge (MBT everywhere), e85 is perfectly safe.
power wise e70 and e85 both deliver identical results.. on a 4g63 they both allow MBT to be reached therefore they max the vehicle out. E85 might give a few more hp over e70 due to the cooling effect more ethanol content has tho.. not much though.
It should be the same for this engine in the ralliart as well. tune safely and all is well.
Old Mar 11, 2011, 11:23 AM
cfdfireman1's Avatar
make up your mind
maybe by you but not around darien closest to me is lombard or glen Eileen
Gas City
8424 Willow Springs Road Willow Springs, IL 60480
or 13059 S LaGrange, Palos Park, Illinois
those are to much out of the way for me
are you sure you live in darien?
Old Mar 11, 2011, 03:16 PM
vplukas101's Avatar
last time i checked yes lol i need one in downers grove or in wesmont and then i would highly consider it
Old Mar 12, 2011, 09:58 PM
How about
MINUTEMAN MOBIL
5500 S LINCLON
LISLE, IL 60532
(630) 963-2810
And where do you think you're going to get Meth in Darien?
Old Mar 17, 2011, 06:30 PM
gccruz's Avatar
I know what you mean. 15+ mi away in the opposite direction of everything else. but i'm still considering it.
majik162189
12
Feb 24, 2016 10:25 AM
Wick3d3vo9
28
Dec 4, 2012 12:01 PM
Evo a Mula
29
Oct 16, 2010 11:12 AM
E85evo8
E85 / Ethanol
Nov 2, 2009 05:15 PM
BCOZEVO
12
Oct 19, 2009 09:02 PM
Quick Reply: meth or 85
