Evo X Turbo Swap
Old Mar 21, 2011 | 08:35 PM
  #31
csra09's Avatar
Originally Posted by Krisko
The gsr uses a different licp than the se and mr, so be sure to verify that before buying it. A good idea would be to try shops who mainly do work on evo's and jdm vehicles or craigslist for the licp. Just search random cities and your bound to easily find one. Plus don't search the evo x engine marketplace section, search the part out's section or try the base model for sale thread.
Good luck with your search!
Theres a difference? I didn't know that..I know some aftermarket companies use a bigger size that won't fit very well with the sst. I used LICP from the GSR.. no fitment issues or anything. I just recently upgraded to the AMS evo X LICP fits like a charm, but does require battery relocation.
Old Mar 21, 2011 | 11:21 PM
  #32
Krisko's Avatar
When I was getting my aftermarket intercooler set put on at evolution dynamics here in dallas (they started NTEC which a huge evo club) they told me they couldn't put on a gsr licp because it differs from the mr/se one. I had to wait until they could find me one to place it on. Plus NTEC is known for dissecting evo's down to the atom and learning every bit and part that makes it run even better.
My added mods were a nesei uicp and oem fmic/licp. I was told getting an aftermarket licp doesn't make extremely noticeable gains like the fmic and uicp does
Old Mar 22, 2011 | 05:44 PM
  #33
csra09's Avatar
As for the OEM LICP I know the GSR piping will fit the RA. I'm not Saying NTEC doesn't know what they saying...just going from personal experience that LICP from 08 GSR fit on my car with the evo x intercooler without any issue.
As for upgrading LICP... i don't think their was ''real'' gain difference. Personally like the design of the AMS LICP may not be a true gain but designed for better performance compared to stock evo x LICP. Also was alot easier to install and like the powder coated black appearance. Just my two cents....
Attached Thumbnails Evo X Turbo Swap-dsc04523.jpg   Evo X Turbo Swap-dsc04525.jpg
Old Mar 24, 2011 | 11:27 AM
  #34
robearralliart's Avatar
I see you have the AMS intake, but does the GSR LICP require relocating the battery, if I have the OEM tube installed?
Old Mar 24, 2011 | 01:50 PM
  #35
velocityhead's Avatar
I don't think anyone has done comparison pulls for just the LICP, but if you look at the stock LICP, there is a big restricting "dimple" in part of it. Not sure why it's there; it's not for clearance reasons.
Old Mar 24, 2011 | 09:13 PM
  #36
csra09's Avatar
I used the GSR LICP when i was using the stock intake and factory battery under the hood with the OEM evo X intercooler....no problems. I don't think theirs a difference in the OEM LICP between the GSR and MR/SE.
Thats true. The design of the AMS LICP is improved over OEM. First the two piece design of the AMS is much easier to install and get lined up. Second got rid of the black ''rubber'' throttle body hose and if you look at the AMS piping see where it goes to the throttle body its much more a straight path. Third if look at where it connects to the BPV it also use a straight path compared to the ''snorkel''. Would be interesting to see pull comparsions even if its not a ''noticeable'' gain.
Couple pics of the oem evo x licp. The metal battery bracket removed for the install of ams licp. Couple pics of the ams licp installed.
Attached Thumbnails Evo X Turbo Swap-dsc04451.jpg   Evo X Turbo Swap-dsc04450.jpg   Evo X Turbo Swap-dsc04527.jpg   Evo X Turbo Swap-dsc04528.jpg   Evo X Turbo Swap-dsc04526.jpg
Old Mar 26, 2011 | 05:59 AM
  #37
spider21's Avatar
03/25/11 Well my car is at Cobb in Plano getting the turbo swap done I hope to post some numbers up and some pictures by late today or Sunday....
03/26/11 Picked car up today made great power today Special Thanks to Cobb Tuning for taking care of me and getting me out very quickly. I have updated my signature to reflect everything that was done.
Old Mar 27, 2011 | 11:03 AM
  #38
spider21's Avatar
Originally Posted by razorlab
I've used the Hawker Genesis mini batteries for 7 years now with no issues in 110F to 10F in both my Evo, my RA sportback and a WRX before that.
They work just fine.
I am using the Braille branded battery because the CCA is rated at 426 its dimensions are 6.8x3.4x6.1 which are comparable to the other small batteries.
Old Mar 27, 2011 | 11:30 AM
  #39
djeuro's Avatar
looking clean
Old Mar 27, 2011 | 05:26 PM
  #40
Chaz17's Avatar
let me know how this turns out! im considering doin the same
Old Mar 27, 2011 | 07:27 PM
  #41
spider21's Avatar
Will do !!!
Old Oct 27, 2012 | 10:43 PM
  #42
HTIEK's Avatar
Really good read in this thread! you guys have a tone of info!
I will be on the hunt for a used X turbo and manifold in the spring!
MattyRalliart13
Oct 23, 2014 06:10 PM
Griffin5
24
Mar 24, 2014 08:16 AM
rschaffer
16
Jun 12, 2012 10:52 AM
ralliartsmart
Apr 2, 2011 08:34 PM
ralli time
Oct 18, 2010 08:18 PM
Quick Reply: Evo X Turbo Swap
