Omegis RA to Evo X swap progress
#151
Started drilling holes on driver's side. After talking to bronto, realized I had safe room to drill holes for tie downs. Also realized I should charge my drill when I'm not using it. Got the holes started and I'll take plenty of pics and try to get a "how to" posted soon. It'll be secured by the end of the night.
Update: Done!
Tucked the trunk mats under the board above the spare tire for now. Battery box from Summit Racing is huge. Probably great for stock battery but big for a small battery. I'll look into cutting out some support material to place in between the battery and box to secure it laterally. It's secure forward/aft and vertically.
Update: Done!
#152
Very informative thread man! just wondering if I can get away with the original location of the RA BOV or do I really need to move the BOV like the Evo X set up?
#153
ETS is one example:
http://www.extremeturbosystems.com/E...-X-Intake.html
#154
Thanks for the links man.
But I think I'll go with the same intake as yours (AEM) coz it looks so neat and I'd like the AEM filter in the box.
So I believe I have to relocate my battery and get the Evo x shorter scoop.
What parts did you use to relocate your BOV?
Thanks
Thanks
#156
I see... Thanks man. If it's ok with you, I would like to ask you some novice questions about the EVO x swap as I'm still gathering all the parts needed.
Coz my worry is the basemap I need to use temporarily when I drive to my local tuner. I believe I can't use the GST basemap once I do the swap even for just a short trip...
#157
#158
A strong insulation job might come in handy when you next have the box open - and are holding a metal spanner in your hand...
Rich
#160
Been looking at doing a turbo application on my ES and was didn't know if anyone knew what parts were necessary to add...besides the entire RA turbo setup that are swapped out?
Noticed a few complete turbo setups for sale from RA owners who upgraded and sell their OEM kits for ~500.
I wasn't sure if anyone knew of anything additional I may be having to look into later on the accommodate for the turbo.
Interesting read, awesome to see other people doing work and not just switching to an EVO.
#161
#162
How do u pinch of the lines? I thought u had to replace the lines with the X lines when doing the swap.
#164
Forgot to mention this sooner. If you go with the AEM intake built for the X, then you'll want to purchase the following mount labeled #6:
http://www.trademotion.com/parts/201...agramCallOut=6
Also, still hunting for a CBE. After 6+ months of research (very picky), CP-E is at the top of my wish list but it seems to be sold out everywhere.
#165
