X swap tuning
I will make swap this coming weekend.
And we start tuning begin of next week,when i get last parts.
Hmm....I have 2010. Can i use that:
54070007_2009_EDM_SS..>
Also what i should pick on EvoScan,because there is no 2010 Ralliart EDM.
And what i should do to have logging work with it?
I cant even get ROM ID.
It cant identify my rom. I can only save .hex file after reading.
What i should do?
Here is my hex file,if its help.
http://livefast.fi/kk/
What i should do?
What i should do?
What i should do?
OK, that is it 2009 EDM ralliart. Go here http://goldenevo.com/ and download both the 53610012 and 53610013 xml files and put them in your C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo directory... adjust the path to suit where your ecuflash installation is. Then re open ecu flash and your downloaded rom, should work like a charm.
looks to me like the id is 53610012 BUT, this is my first time trying to find an ecuid so take that with a grain of salt.
Thanks You are man
I think it works now. Im so out of understanding when comes to computers and ecu´s. Body & mechanical work is my business.
I just want check that everything works and i can save orginal ROM before swap.
Evoscan and Ecuflash is also new things to my tuner too...
Ok. So car is just registered 2010 then. But model is 2009?
So when i take MAP tables to EvoX swap i should take them from 54070007?
Right?
And what should i take and do to make datalogging work in Evoscan?
Thanks You are man
Right?
Right?
As for logging.... I can't help there unless there is a 2009 EDM X in the drop down list..... I'll dig around and see what i can find real quick.
Thanks for all help! Very kind that you had time to help.
Yes,all info is needed. I will tell him this all,if he doesnt figure it out on own in first thing.
Now i think i can start swapping and just trusth that all tuning things work next week,when we start.
Still wondering that Evoscan thing.
No 2009 EDM Ra. What i shoud pick up?
I really need to log Knock.
And yes ID is that what Mad_SB told. 53610012
https://www.evolutionm.net/forums/09...f-dummies.html
Yup, Evoscan and the Evoscan addresses that richardjh has been using:
Okay.I had now read it couple times,and think i understand all.
I have small language problem
BUT.
My Rom Id include these:
<rom>
<romid>
<xmlid>53610012</xmlid>
<internalidaddress>5002a</internalidaddress>
<internalidhex>53610012</internalidhex>
<make>Mitsubishi</make>
<market>EDM</market>
<model>Lancer</model>
<submodel>Ralliart</submodel>
<transmission>SST</transmission>
<year>2009</year>
<flashmethod>mitsucan</flashmethod>
<memmodel>M32186F8</memmodel>
<checksummodule>mitsucan</checksummodule>
</romid>
<include>53610013</include>
</rom>
So i just add rest of it what richard have in code section?
I have that "<include>53610013</include> ". And he have " <include>evo10base</include> ". So what i should do with this. Do i keep my or change to that "evo10base"?
