X swap tuning
X swap tuning
So, I just have a few pieces left to get my hands on before the X turbo swap. I've been looking over my rom collection and have noticed that the RA and the X have unique tables for Map engine load and Maf scaling.
For a minute there I was thinking about just swapping in the X map engine load tables and the maf table (assuming I swap over to an X maf housing / intake setup). Then pulling tables from one of my old X gsr basemaps to create a base map for the swap....
However, after giving it more thought.. messing with the map engine load tables may not be the best idea if there are other load related tables that we / I do not currently have access to... specifically SST Related tables (torque limits, shift point logic, requested torque, etc etc).....
Just wanted to get a feel for what others have done with tuning X swapped ralliarts.. Maf table is no big deal, mainly interested in everyones take on the map engine load tables and if they were changed when doing the swap.
Rumor has it that its much easier to switch to X VE and Timing Tables rather than correcting RA ones. I dont know this from first hand experience, but reputable sources (you know who you are ) have stated this to be the case.
You'll need to swap over the MAP table values as they are VE tables. Your load will be all wack with the Evo X turbo and MAF if you don't, and some other weird little things happen.
Your assumption of moving over the Evo 10 MAF scaling is correct as well (if you go to a Evo X MAF housing)
Nice!
On a side note, how much work did you have to do on the rear fenders to fit the X wheels on your SB? I test fitted one of Seth's wheels (with 245 z1 run wide as heck star specs) and I swear the rubber was 1/4" outside of the fenders
My tuner has a close friend who has a 2011 GSR that he can easily use for reference for when my X swap is done. He first mentioned if it was possible to just copy over most of the tables, but the swap was still a while away so I didn't bother to ask for which specific tables (his 2011 GSR is stock right now, just like mine will be after the swap). Now I have a better idea
Will be interesting how the RA comes out with the exact same setup
So if i get this right.
When EvoX swap is done,best base to start tuning is copy EvoX MAP tables over Ralliart´s own? And start tuning from that.
(sorry i dont understand english so well )
