Should I upgrade ic?
For $500 you can purchase an ETS EVO X 3" FMIC kit with silicone couplers and stanless tbolts that will bolt right in, and can easily handle your power estimate. If you go that route, you need a 2-1/2" to 2-1/4 silicone coupler to use the stock RA LICP. An aftermarket 2-1/2" UICP is recommended, and should come with a 2-1/2" to 2" adapter for the turbo outlet.
I am happy with my ETS FMIC with just 3" turbo back exhaust, UR UICP, EVOX BOV, and Cobb AP Stage 2 93 Octane map it performs great. I will be installing the CBRD RAD turbo in the very near future to complete my engine modifications, and expect the cooling capacity of the FMIC to easily exceed my power requirements.
You "should" be fine w/ the X IC. Upgrading to something bigger & more efficient is a luxury but, by all means, if you have the funds you should definitely go bigger than the stock X IC. The great thing about replacing the IC is that's it's a somewhat easy task and you will have the option to resell your X IC later on if you decide to upgrade.
I've got the X IC on my RA now and I'll stick with it after I do my X turbo swap but when I have the funding to splurge, I'll probably upgrade to either the UR or ETS IC.
Like Brian said, it's really all about your financial standpoint.
BTW, unless I'm reading it wrong, looks like an MR that Brian tuned was running stock IC just fine around 350hp:
https://www.evolutionm.net/forums/ev...some-ssts.html
On another note, I spend wayyyyy too much time reading and researching on EvoM which is why I almost always link to other posts.
inariv5573
16
Oct 27, 2005 11:48 PM
MR 600
17
Oct 27, 2005 12:45 PM
SA_Evo
10
Oct 13, 2005 06:36 PM
