RalliArt blown up! why? help me!
Old May 22, 2011, 07:35 AM
omegis's Avatar
Originally Posted by mad_sb
btw, this is one of the reasons why any turbo car should have a wideband......
+1
Old May 22, 2011, 03:56 PM
yby
yby's Avatar
Originally Posted by razorlab
Yea if that hose was off you went lean, probably melted a piston.
Yep I'd have to agree with Brian on this one. With the Fuel pressure regulator hose off the fuel presure won't increase as the boost increases. You'll end up with a massive lean condition....Mininium holed/melted piston. However you're video has a real metalic sound at one point so I suspect there's something else broken too.
Sorry to be the bearer of bad news...
Old May 22, 2011, 05:45 PM
omegis's Avatar
Lesson learned from this, I now realize there is nothing really securing that hose. Looks like I need more hose clamps to avoid this from happening.
Old May 23, 2011, 12:22 AM
bronto11588's Avatar
Agreed my new engine im clamping every mother tucked down lol zip ties are now my best friend haha oh well lesson learned problem will be figured out soon and fixed soon after even if I have to replace the engine I love my car to much to just let it go
Old May 23, 2011, 11:52 AM
sstevojr's Avatar
Ya with tha amount of work you've put into her, I wouldn't let her go either
I think I've seen some blocks listed for $2-3K depending on mileage, if that helps; good luck!
Old May 23, 2011, 12:25 PM
nunyas's Avatar
long and short blocks come up in the EvoX private sale section every now and then. That may be a good place to start...
Old May 23, 2011, 05:34 PM
RalliMark's Avatar
You probably will want to put a wideband in when u put the new engine so it doesnt happen again.
Old May 23, 2011, 07:54 PM
Slee256's Avatar
Can you give me some details on the hose clamps you're referring to here please?(type, brand, picture, where can I get them, etc.) I'm just using a ziptie right now, but I still feel like I can't get it as tight as would like on the hose, and so I was wondering if there was something else that would be more secure and reliable.
Old May 23, 2011, 09:44 PM
richardjh's Avatar
I'm thinking glue, myself!
Rich
Old May 23, 2011, 10:07 PM
TOralliart's Avatar
I wonder why the SES light didn't come on if it was running lean.
Old May 23, 2011, 10:54 PM
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
The mini small zipties work fine. I use them on both my Evo that has seen 30psi and my RA which has seen 28psi. The trick is to use the mini zipties, not the normal size.
For added security you can also use hair spray.
No CELL would be trigger for lean mixture at WOT.
Old May 24, 2011, 12:24 AM
Well tomorrow is the day. I have to go and see the damage done and decide on what to replace and what to replace it with. I can say for sure im not going back to stock at least replacing pistons rods valves camshafts and getting a resleeve
Old May 24, 2011, 12:41 AM
3grst01's Avatar
4g64 swap
Old May 24, 2011, 11:17 AM
nunyas's Avatar
EvoX stroker kit
Old May 24, 2011, 01:57 PM
lol^^ going with sleeve pistons rods cams and hoping nothing on the head is damaged lol
Quick Reply: RalliArt blown up! why? help me!
