Red devil project
Old May 26, 2011, 03:42 PM
El-Diablo's Avatar
Red devil project
I am in the process of molding the red devil the following is the current mod list:
Stage 1 complete.
HKS Legamax cat back - installed
Boost pill - installed
K&N filter - installed
Creatd Motorsport UICP - installed
Creatd Motorsport tune - installed
Current power 180 kw ATW I will post current dyno graph.
Stage 2
Perrin intercooler - purchased
HKS o2 and dump pipe
Cbrd rad full
HKS bov - purchased
AEM cold air box
Big brake upgrade
Any suggestions or recommendations as to additional items I should consider eg
Fuel pump
Injectors
Boost controller
Wide band (not sure what this item actually is )
Please when making a recommendation list manufacturer and your experience with the product/ benefits
Old May 26, 2011, 04:25 PM
sstevojr's Avatar
SUSPENSION!!!!
This car makes power sooooo easily, that before you know it you have gone beyond what the stock system is designed to handle (if you drive anything other than a straight line). Do yourself a favor and work with someone reputable in your area to get a suspension system set-up; wont do you any good to wrap your car around a tree, cuz the power was so overwhelming taking a curve you let off the gas, causing your weight to shift drastically
If we had cars that weighed like 3000 lbs, wouldn't be nearly as big a deal, but we got ourselves a big girl that likes to be ridden rough ;p
Old May 26, 2011, 06:17 PM
Jay10Ralliart's Avatar
When you go with the boost controller go with the Grimmspeed EBC. You will then need to unistall the boost pill. I would install this when you install the intake and turbo because your car will need to be retuned. If your going to wait on the turbo a bit then just install the EBC with the intake because once those parts are installed a new tune will be required. Also the wideband is an air/fuel ratio gauge I have the AEM one installed on mine.
Old May 26, 2011, 10:01 PM
hixlancer's Avatar
i believe with the rad full you will need bigger injectors. wait until you have everything and throw it all on at once and get a tune. save some money.
Old May 27, 2011, 05:31 AM
Cesarn2928's Avatar
my car is red devil
nvm its red demon lol
Old May 27, 2011, 06:24 AM
initial_d2k's Avatar
Swift Spring or Coilover
Whiteline Front/Rear Sway Bar..
Old May 27, 2011, 06:31 AM
crrowley12's Avatar
AEM seems to be the most trusted wideband to go with. I have it on my car. People will ask if it's really worth it or not? Well it depends on how much you love your car. If you're allergic to money and don't care about it, then don't install one. If you are like many of us and find your girlfriend being jealous of your car, then get one. The wideband will tell you your air to fuel ratio. Meaning that it tells you if you are running rich, burning too much gas, or lean, not enough gas. Too much just means that you are wasting gas, and money. Running lean is not good for your car. Basically you want to know this to know if something is wrong with your car. If your numbers are normally in the high 14s and then all of a sudden you're running around 17, then you know you have a problem and need to get it looked at. Your car can't tell you if something is wrong, so you have to take measures to find out on your own.
Old May 27, 2011, 08:42 PM
Jcusco407's Avatar
CBRD is not making the rad full. Its too much for the transmission
Old May 27, 2011, 09:35 PM
El-Diablo's Avatar
CBRD are making the rad full I am currently organizing an exchange unit for upgrade.
Old May 28, 2011, 09:54 AM
nunyas's Avatar
that's fascinatingly good news to hear. I'd like to see what kind of boost that will hold out to redline....
Old May 28, 2011, 10:01 AM
NFSLancerRA's Avatar
Where do you get this stuff?
Old May 28, 2011, 10:02 AM
This transmission can handle well more than the RAD can throw at it.
Old May 28, 2011, 11:43 AM
sstevojr's Avatar
^ Yeah I'm going to second that, the SST with a proper tune can handle way more than the RAD can spit out (but she seems to be a good little turbo, haha)!
Old May 28, 2011, 06:20 PM
NICK(PMR)'s Avatar
Cant wait Rob looking forward to seeing some great numbers.
Old May 31, 2011, 07:56 AM
Jcusco407's Avatar
Quote:
Originally Posted by 08Lancer89
"If I want a full turbo would it make more power than the lite?"
its not going to pick up much at peak, it spools quicker-
BUT the drawback is the earlier spool is really going to give the SST a workout.... I may not offer it because I dont want to offer a product that will then cause headaches with the Trans!
cb
I remembered reading somewhere that he wasnt going to make the full. After finding this again, I realize it wasnt a conclusive decision. Sorry for the confusion
