Gauges?
Gauges?
So i want to get guages in my car, I was looking at Glow Shift. I read though that they arent the greatest which leads me here. I want to know what people have and how much they paid, etc.
Looking forward to hear from everyone, also if you can post a pic of your setup that would be great!
I have the rexpeed dual pillar pod. Fitment is decent, but not perfect which bothers me. In it I have the AEM wideband, usually around $180, and a glowshift boost gauge. If all you want to do is look at it, then it's fine. The button that changes the colors doesn't work and the boost line supplied barely freaking reaches far enough.
Running AEM UEGO Wideband and AEM Boost gauges in a CP-E dash pod. Still need to decide what I want to do with the third space. I thought I was going to stick with a trans temp gauge, which I probably still will but idk, so I'm currently running a blank so it doesnt look like a gaping hole...
Gauges match OEM gauge look identically when turned off. Lighted up, the red setting looks exactly like the red of the heater controls, etc., but the white is a brighter (more LED-ish) white than the yellowed OEM gauges. I suppose that could be fixed with a slight OEM cluster modification though. Pic later today hopefully
Im also running an AEM wideband and AEM boost gauges just like 03chi-town0Z but Im using the Rexpeed cf steering wheel dual pod. Gauges run around a little less than $350 and the pod was around $100.
Want
Dec 16, 2013 11:13 AM
