Ralliart Only Exhaust Systems
Guys and Gals, I know someone has posted about this before but the info seems to be all over the board. I'm researching exhaust systems for the 09+ Ralliart. If you have an aftermarket Turbo Back or Cat-Back please chime in. Also please include dyno numbers if you have them. I will probably go with the Turbo XS but I want to be completely sure before I invest the cash. Thanks in advance!
Thanks Steve.
OP, use that list and then try going to the "Advanced Search" function and enter each of the exhaust names that you are interested in. Then in the bottom right corner, make sure you have chosen the 09+ Ralliart Forum section to search within. These have all been beaten to death.
AMS or any other single-exit will be lightest and will help make the car quicker via weight reduction. CP-E and AMS have provided dyno results for their exhausts. I'm sure there are others out there that have, as well, but those two are the ones that come to mind right away.
HKS make a beautiful work of art Ralliart Exhaust buts its expensive. I have the cat back and am either buying the downpipe and housing or changing to a full 3 inch on my evo x swap.
CJK
34
Apr 1, 2017 05:24 PM
aaronk
Canadian Forum
Jul 1, 2012 10:19 PM
