ACD Service Required
Today the ACD Service Required light popped on the RA. Since its Labor Day weekend I can not get into the shop till Wednesday of next week. The RA did not throw any codes.
I have not noticed and issues... I did some research and Im leaning towards the ACD pump is shot! or its low on fluid. but what do I know...
Anyone have any issues with this before? I used the search button but haven't found anything really helpful...
Anyone have any suggestions on what the problem maybe and possibly where to start?
Thanks in Advance!
Thanks in Advance!
Thanks in Advance!
Thanks in Advance!
I don't want to scare on this but how many miles do you have? Hope this will work out man. Just have them look at it and take it from there. You can drive it since it is in a safe (trip) mode now. But how much driving are you planning to do? Sorry to hear about this especially being on a weekend like this.
We do know how this "works" with the powertrain system along with our AWD control but the Mitsubishi says it is a "luxury" item, so therefore it will NOT be covered under powertrain. But if you have it under 36K miles, then it will be covered unless you have an aftermarket warranty to cover whatever that do not cover after 36K miles. Hope this helps.
45k miles and I knew it wouldn't be covered but just wanted to know if anyone else had this issue.
I wont be driving much. After I turned my car off the light never came back on
It can set you back a good $1700 to $1900 for the part and labor alone. It costed me a good $1900 for it.
Which manual? The main one or the Ralliart spec? I do not see anything on mine..could it be the 2009 did not have this dotted down on the manual?
i had the acd light come on in my 2009 ralliart as well. it would not come on right away at first only when driving (transmission heated up) then came on all the time by the time i could get an apointment. braught it to the dealer and they said the acd pump was not working properly or at all. they replaced it with no issues under the 100k powertrain warrenty. My transmission has some issues with the gears now and is jerky at various loads/gear changes but isnt "broke" enough for them to warrent a transmission change but as for the pump they changed it right away with no hassles. i live in canada but dont think it should be any different anywhere else?
Has anyone found a service interval for the ACD fluid?
I had mine changed today, and will be doing so ever 2 years or so going forward in the absence of any formal schedule from Mitsubishi. The fluid looked to be clean, but I'm tracking the car so I'd like to stay on the safe side. The fluid isn't very expensive either.
The pump itself looked good and has been covered in anti-corrosion spray. Fingers-crossed it all remains healthy.
Thanks for the info.
I may push my ACD service interval out to 3 or 4 years in that case, but I have a hard time believing there is absolutely no degradation of the fluid over time, sealed system or not.
I had this problem too. my dealer re-flashed mine also. I was concerned that it may be more. So the tech came out and walked me through the Mitsubishi flow chart for this problem. They said this was covered under power/drive train till 60k. but since we had started the process while under warranty and it went out after warranty they would still honor it.
But my dealer is also cool with all my mods, haven't even said anything about my CEL for my test pipe.
It will also give you the "Service Required" if:
1)You are using different tires, as it "thinks" they are spinning out of sync
2) You go through a low pressure/temp drop situation
The owner's manual says that for #2 the system is registering a "potential change in viscosity" of the fluid. Pull over and turn the car off; when you re-start it if the light is off you are fine. If the light stays on, or persistently turns on over and over, then actual service is required.
kyoo
618
Jul 27, 2022 11:38 AM
Rotten Egg
Oct 26, 2011 05:16 PM
