Manny Tranny
Old Oct 12, 2011, 07:46 AM
Veronica's Avatar
Manny Tranny
If (God Forbid!) the transmission fails outside warranty...
What manual transmission options are there? I figure it would be cheaper to convert to an EVO VII (? VIII? X?) manual transmisison...
I say this because you could get the pedal set from a wrecked Lancer, and the transmission and shifter assy from a wrecked EVO...
But what else? Do the ECU requirements kill the deal? Do the shafts and tranny bolt up? Mounts? What else makes it too difficult or expensive?
I am thinking feasible and practical (total project costs less than a swap of a TC-SST)
Thanks!
(and if a search would have revealed this - i will take my beating! )
Old Oct 12, 2011, 08:31 AM
Jasoob's Avatar
I think an Evo9 swap might work since the drivetrain is the same.
Old Oct 12, 2011, 08:45 AM
adog's Avatar
An evo x 5spd should bolt up with little modification since it's the same engine. I remember that the argument against it was the fact that the evo x tcu would always be looking for the ayc but we had a fellow ralliart member bolt up a sst from an MR and it worked just fine. As far as costs you can pick up a 5spd for 1500 in the fs section plus shift linkage and installation it shouldn't cost more than 4k to swap it out. I'm actually going to talk to mike at rre to see if this is possible bc I have 6k ready to go into the ssp trans upgrades but if the trans craps out on me it's 12k down the drain
Old Oct 12, 2011, 09:55 AM
pbassist12's Avatar
+1!
Very interested in this! I was thinking the same thing. Would it be possible to get a 6 speed trans??
Old Oct 12, 2011, 10:44 AM
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
It's not the same drivetrain as a 9. The tcase,etc is Evo 10 specific.
I hate when people say it's the same as the 9 and people take it literally.
It's using the same TECH as the 9, meaning the RA doesn't have AYC like the Evo 10. Everything else is the same.
The ACD/AYC uses a seperate ECU then the engine ECU or the Transmission TCU.
ACD / AYC activity has nothing to do with the actual engine or transmission.
Old Oct 12, 2011, 12:00 PM
adog's Avatar
True but the argument was that the TCU is in constant communication with the ayc computer so when you tried swapping in the 5spd it would constantly be looking for the ayc, because of this no one knows how the transmission would react but if someone managed to put an MR transmission in without any problems why not try a 5spd
Old Oct 12, 2011, 12:08 PM
RazorLab's Avatar
No it's not. The AYC has nothing to do with the TCU / Transmission. The RA has a ACD/AYC ECU just like the Evo 10. The ACD/AYC share the same control unit, which is seperate from the ECU and TCU
TCU and ECU communicate. ASC is tied into those. Obviously the ACD/AYC control unit get CAN information just like all the other control units because it needs to know g/yaw/speed/etc information.
Swapping a Manual transmission into the car doesn't change the transfer case, where ACD is contained, doesn't change the rear diff (AYC or not), doesn't change the ACD/AYC control unit (which the RA has). It does change the TCU which is intergrated into the SST Transmission. This is where the unknown is if you take it out of the equation.
Old Oct 12, 2011, 12:14 PM
adog's Avatar
So then swapping in a 5spd might be as easy as doing it on a civic? Cuz ill gladly be the guiny pig to see if it works and how hard the install is and anyone who says just buy a GSR don't worry I am but I still want a 5spd ralliart
Old Oct 12, 2011, 04:42 PM
richardjh's Avatar
> LOOK
YOU ARE IN A TWISTY MAZE OF WIRING LOOMS, ALL ALIKE.
> GO WEST
YOU HAVE FOUND THE ECU
> TAKE ECU
YOU CANNOT PICK UP THIS OBJECT
> FLASH ECU
DISASTER! YOU HAVE BRICKED THE ECU!
Rich
Old Oct 12, 2011, 06:02 PM
NFSLancerRA's Avatar
That is a negative, goat-rider. We have a couple of parts (albeit some very crucial parts) in common. That is about it.
For electronic advice, go with Bryan.
Old Oct 12, 2011, 06:07 PM
RazorLab's Avatar
Goat-rider? lol!
Old Oct 12, 2011, 06:12 PM
You know that you are going to use that now.
Old Oct 12, 2011, 06:16 PM
masafina's Avatar
eye on here!
Old Oct 12, 2011, 06:26 PM
Originally Posted by masafina
eye on here!
Mi coche es un chulo susio. Este carro tiene transmisión automática (mas o menos). Las cabronas me muestran sus tetas en mi coche con la automática. Está bien así.
(Perdóname. Mi español no es muy buena.)
Old Oct 12, 2011, 06:27 PM
I looked none of that up, by the way.
Quick Reply: Manny Tranny
