E85 on maxed out turbo?
Old Jan 5, 2012, 12:58 PM
bwanner's Avatar
Would e85 help out in hp numbers if the stock ra turbo is maxed out around 270whp?
Old Jan 5, 2012, 01:46 PM
stfuad's Avatar
I'm admittedly uninformed but, no why would it? if a part maxes out at some value how would changing the fuel type help?
Old Jan 5, 2012, 02:23 PM
sstevojr's Avatar
e85 allows for more timing and cylinder pressure. I have not had the pleasure, but I would imagine even with the tiny RA turbo you could max out the MIVEC intake and add a handfull of degrees
Old Jan 5, 2012, 03:17 PM
pbassist12's Avatar
^^ very true. kyle is doing great things with his car
Old Jan 5, 2012, 03:21 PM
2muchboost's Avatar
I gained 25hp and 60tq going from 91 to E85
A big chunk of those gains are from the initial boost spike but the car is obviously faster on E85
Old Jan 5, 2012, 04:22 PM
bwanner's Avatar
ya i know e85 explodes much faster so wouldnt that require more air then cause there more gas going through?
stock ra turbo?
Old Jan 5, 2012, 04:49 PM
2muchboost's Avatar
stock ra turbo?
Actually E-85 burns slower than regular pump, that with the additional cooling properties in the ethanol allow you to run more timing/boost without knock.
Yup, Stock RA turbo with AEM Intake, X intercooler, UR upper & Lower pipes, 1000cc injectors, Ultimate racing turbo back exhaust, and a 3-port
Old Jan 5, 2012, 05:07 PM
bwanner's Avatar
What are you running for boost and do you know your whp #'s?
Old Jan 5, 2012, 05:14 PM
2muchboost's Avatar
233whp/ 258tq on 91---24psi spike, tappering down a lot by redline
258whp/ 322tq on e85--27psi spike, tappering down a lot by redline
This was on a Mustang Dyno
Didnt get a baseline but other stock Ralliarts have dynoed in the 190-200WHP range.
Old Jan 5, 2012, 05:28 PM
sstevojr's Avatar
That is one hell of a torque punch, good times!!
We still going to meet up for some track days 2mb?
Old Jan 5, 2012, 06:08 PM
AlphaKennyBody's Avatar
Anthony... You gotta give me a ride in the car...
Old Jan 5, 2012, 06:40 PM
bwanner's Avatar
Do you have quarter mile time btw?
Old Jan 5, 2012, 07:11 PM
pbassist12's Avatar
why does your boost taper down a lot?
Old Jan 5, 2012, 09:07 PM
Cause it's the stock RA turbo... lol
Old Jan 6, 2012, 12:11 AM
pbassist12's Avatar
good point.. lol good thing im upgrading
Quick Reply: E85 on maxed out turbo?
