4g63 flywheel on 4g69?
can a 4g63 (95-99) flywheel fit a 4g69? at eye they seem the same, and the clutch i'm using atm is from a 4g63 act. (on mi 4g69)
i found a fidanza flywheel from a 4g63 95-99 new cheap, maybe tomorro i will go to compare it with a 4g69 i have spare. if some one know anything will help me alot.
sorry for the english i'm from PR.
ACT has different part-numbers for their flywheels (4g63 vs. 4g69). I would guess no. However, the 4g69 and the 4G64 are very similar. The transmissions are completely different. I wouldn't do it.
No problem. The evolution of the 4GXX line of engines is actually pretty interesting. Remember, when you compare the two flywheels, make sure to take the height into account. I suspect that the difference in bell-housing may mean that this is a no-go, but hey, stranger things have been accomplished with older power-trains.
