Upgrade
Old Mar 17, 2012, 05:59 PM
spider21's Avatar
Thumbs up Upgrade
I have started the upgrade again for more power and should be putting up numbers by end of the week. Here is a list of items that are being done.
Turbo - MAP EF2
Exhaust Mani -MAPerformance Exhaust Manifold Port and Polish
Intake Mani - MAP Rev 2
Throttle Body - Mil.Spec
Injectors - ID1000
Cams - Kelford 214b
Fuel Pump - Walbro 400lph
My signature has my current mods in it.
Old Mar 17, 2012, 06:15 PM
silthos's Avatar
Look forward to seeing your results. Solid set of mods.
Old Mar 18, 2012, 11:12 PM
pbassist12's Avatar
Also cant wait to see! More and more higher hp builds with the SST
Old Mar 19, 2012, 03:52 PM
AWDralliart09's Avatar
Heck yah, this gonna be 1 bad Ralliart!!
Old Mar 19, 2012, 04:04 PM
OverCorrupt's Avatar
sounds like its gonna be SICK NASTY! cant wait to see what it can do!
What are your plans as far as getting the power past the tranny? gonna upgrade the clutchpacks or just do a safe tune?
Old Mar 19, 2012, 05:04 PM
spider21's Avatar
Safe tune for right now and clutch packs at end of year...
Old Mar 27, 2012, 10:09 PM
spider21's Avatar
Update hope to have numbers posted soon
Old Mar 27, 2012, 10:14 PM
silthos's Avatar
Can't wait to see this monster!!!
Old Mar 28, 2012, 10:32 AM
Jasoob's Avatar
If you got the clutch pack+tranny cooler+SSP fluid+larger tranny oil pan, you could destroy with that set-up. I'm sure you could get to the 400whp/400wtq range.
Old Mar 28, 2012, 10:56 AM
NFSLancerRA's Avatar
As long as the boost comes in later, the pistons and transmission should be okay (at least for a little while). That MAPerformance Manifold is so good looking. They definitely do some excellent work. I have seen it first hand.
Old Mar 28, 2012, 10:58 AM
Eventually, he is likely going to need the Dodson setup. It might take a while to slip the the stock clutches, if everything is tuned properly. I am more worried about the motor. I am not quite at that power level, yet, and I am still have my motor completely rebuilt before proceeding further.
Old Mar 28, 2012, 12:10 PM
spider21's Avatar
I made 360hp and 364 tq I am still running stock cat back so this is the limiting factor and this is done at 26lbs of boost I will post a graph with an overlay of my previous numbers. The car is a night and day difference even at these power levels since the tq is not dropping off anywhere like the stock x turbo was. I am very pleased with the upgrade and I will make the 400hp number sooner or later hopefully this year especially if I decide to upgrade to the dodson clutches and the factor I am at 70k miles on the motor.
Old Mar 28, 2012, 12:31 PM
sstevojr's Avatar
How does the engine feel with +70k miles?
Congrats on the power upgrade, look forward to the new graph
Old Mar 28, 2012, 01:10 PM
Jasoob's Avatar
Aren't most of the EvoX's running this power level? Have they had engine issues? I thought the engines were able to handle it. Good to know!
Old Mar 28, 2012, 02:45 PM
No, the maximum torque threshold for the stock motor is 400 wtq. Some people have been able to sneak by for a little bit above that level on the stock block, but it is unadvised. They all eventually fail. I am at 374/373, and I am about to build the entire thing. It does depend on when the torque kicks in...etc. etc.
Quick Reply: Upgrade
