Turbo swap question
Old Apr 4, 2012 | 05:41 PM
robyn402's Avatar
Turbo swap question
so when you swap out the oem turbo for a RAD do you really need to drain the engine oil and coolant like the service manual says or can you get away with not doing it and just disconnecting the lines?
Old Apr 4, 2012 | 08:30 PM
sstevojr's Avatar
Give it a try, let me know how it goes
Think about it, would you replace a radiator and leave the coolant in the engine?
Old Apr 4, 2012 | 09:56 PM
richardjh's Avatar
I seem to recall someone (Bryan?) mentioning that it was possible to pinch off the rubber coolant lines... if you did it carefully, and didn't damage them.
Rich
Old Apr 4, 2012 | 10:06 PM
sstevojr's Avatar
I think your right about the coolant line.
Old Apr 5, 2012 | 12:28 AM
robyn402's Avatar
yeah, pinching or blocking a line is what i'm talking about that cool for rubber coolant lines... but what about the oil
i just figured someone, somewhere has a shortcut i'm not thinking about, but i have a feeling i'm just gunna end up doing some draining... not a big deal but if i can avoid it, bonus
Old Apr 5, 2012 | 08:08 AM
Bom's Evo's Avatar
It's part of the labor of a turbo swap, oil change and coolant flush.
Old Apr 5, 2012 | 08:10 AM
Veronica's Avatar
If it is 'close' to being due for a change - you would drain/change.
If it is fine - then just cap/plug/pinch the lines....
Old Apr 5, 2012 | 09:04 AM
richardjh's Avatar
I'd say drain/refill the oil regardless. It's cheap, it's easy...
Rich
Old Apr 5, 2012 | 09:20 AM
sstevojr's Avatar
Coolant is pretty easy as well, there is a drain sock at the bottom of the passenger side of the radiator.
Old Apr 6, 2012 | 08:22 PM
billyboy1's Avatar
i pinched the lines so they didnt leak and worked fine
Old Apr 6, 2012 | 08:35 PM
jrank3792's Avatar
Get a 3/8" (I think) bardb and just connect the two coolant lines.
Old Apr 6, 2012 | 11:55 PM
robyn402's Avatar
so coolent taken care of, no tricks for oil lines?
Old Apr 9, 2012 | 06:28 PM
EyeDreamt's Avatar
Oil barely leaked. Coolant... drain that. I thought I'd just pinch/attach together, and I ended up with coolant all over the garage floor.
Old Apr 9, 2012 | 07:32 PM
RalliMark's Avatar
Oil doesnt really come out since the engine isnt running and its all sitting in the pan. I would change the oil regardless. I didnt change mine until after I was done with the swap though. The coolant is most likely going to go evey where if u dont drain it first.
Old Apr 10, 2012 | 11:36 AM
Jasoob's Avatar
I'm glad I just read this thread!! I'm going to be doing a Rad Lite soon as well. I'll flush and change everything.
