RA´s S-sport and launch. DONE
#198
Crak - the 2010 did have a tune on it.
after reflashing the stock rom was on the car - and it worked as it should
i then flashed a tuned rom onto the ecu - still worked as it should. and that rom had modified SST tables on it also (pretty similar to the GST public roms, nothing too crazy)
this might be completely ludicrous - but what if you USA guys flash a euro/aussie rom onto your cars?
ie when you do the SST flash, code it for a euro VIN and it will drop a euro rom on the ecu??
the worst that could happen is the MUT3 errors out on you because of the VIN clash.
just a thought....
just a thought....
#199
Bad news:
Auffenberg in O'Fallon IL are a bunch of bastards. First the lied and said they didn't even have the MUT III or Medic, then when I pointed out that they did they said "well we dont work on Mitsubishis anymore" as a Outlander was being driven back from the drop off bay. I offered em $100 just to use the tool and the manager told me to go find a Mitsubishi dealer that was still open. You'd think they'd want to use it while they have it and make some money, guess not.
Good news:
I have an appointment with a dealer in St. Louis to "flash my stock SST programming I have on a disc back to my car cause the aftermarket one is causing me issues."
Hey, it's worth a shot.
Good news:
#201
just a thought....
just a thought....
good suggestion though!
#202
Bad news:
Good news:
Good news:
wow that dealership in IL are a bunch of bastards. I bet ya, if you just walked into the garage and didnt even bother with a service manager, went up to a mechanic and said, hey bud, "give me the MUT3 for 15min and ill give you 100$". I bet ya that would have worked right then and there.
#203
nice! good luck with that!!!!
#205
Think till will help with anything?
http://89.252.58.233/ps/MUT%20-%203/...F_INFO_TBL.mdb
password is: DGPLQ_PPF
master cd: http://89.252.58.233/ps/MUT%20-%203/...COPY%20MASTER/
i looked it over, and theres no info on the CFF_SST files...beats me.
Check out the CFF_SST folder, it has a bunch of other .cff files...IF only there was a way to read them and find out which year they are for.
#206
Here's another data point for you rich:
2011 USDM Mitsubishi Lancer Ralliart - Super Sport AND Launch Control on and working. Though I get a "slow down" and kicked out for gear when I launch I figure it has to do with the fact that my ralliart has aftermarket turbo, e85, its 95 degrees out. And I'm on a custom tune that has never had to account for launch control with all the changes in the SST tables. Gonna put all those to stock and see what happens...
#207
So you got a dealer to do it for you?
#208
I got a dealer to "flash the original european tcm file i had on a disk to my transmission I got from some guy in europe because the US file a friend had flashed to it caused some codes to pop up". Really he was confused about the whole thing so He just let me plug his VCI into my laptop with MUT III on it and flash it myself
Cost me a hour of timr @ $89. but well worth it.
Gonna send you a log of 3rd in s-sport.
