RA´s S-sport and launch. DONE
Old Sep 6, 2012 | 07:34 AM
  #226
EyeDreamt's Avatar
Originally Posted by crak
Send me one too
You already have it, you just don't know it
Old Sep 6, 2012 | 09:06 AM
  #227
crak's Avatar
I know what you mean! lol
IS there a fast way to download the entire folder instead of one file at a time?
Old Sep 6, 2012 | 09:57 AM
  #228
EyeDreamt's Avatar
WGET is what I used, I forget the exact command.
Old Sep 6, 2012 | 10:24 AM
  #229
Mad_SB's Avatar
Originally Posted by richardjh
Technically, yes, it's possible to mod the ROM to do that. I considered it at some point... kind of an unholy SST version of Tephra's XMOD AltMaps. Lower boost in NORMAL mode, etc. Never did it, though. It seemed like lots of work - and wouldn't have been something I could share with others.
But not a good plan for different fuel types... Any idiot could jump in your car, flick the button, drive it hard and blow up the motor.
Rich
PS. Off-topic, lol.
Perhaps we should start a new thread about this idea. I have wanted this for some time. The clutch pressure is so low in normal mode that I can't go wot without them slipping all day long... so it would be very nice to at least have boost maps tied to the sst mode. I would run spring pressure in normal mode, 21 in sport and 25 in S-Sport.
Old Sep 6, 2012 | 10:32 AM
  #230
TurtleRA's Avatar
wget -r -np -nH http://89.252.58.233/ps/MUT%20-%203/
This worked for me. It will only get the recursive directories, because I can promise you, you don't want what is in the parent directory.....or maybe you do. NSFW
Old Sep 6, 2012 | 11:02 AM
  #231
Jay10Ralliart's Avatar
FCOTM Winner
I really want to take advantage of this but I really dont understand much about it or have the equipment to do it. Anyone in the NW Indiana area have the equipment and could possibly help me out?
Old Sep 6, 2012 | 12:13 PM
  #232
EyeDreamt's Avatar
Mine was that, with a small bit to not get the index.html files.
Old Sep 6, 2012 | 12:16 PM
  #233
TurtleRA's Avatar
Now how do you install it, I get stuck at the MSDE install part, it just sits there. If i use the copy master one, it starts to install, then just quits. Sort of lost in what to do.
Old Sep 6, 2012 | 12:41 PM
  #234
EyeDreamt's Avatar
burn each of the directories to cd and install from them. Master, then update. I had to use XP because win7 gave me issues. Lucky for me I had my old tuning laptop just collecting dust so throwing XP on it was no problem.
Old Sep 6, 2012 | 12:50 PM
  #235
TurtleRA's Avatar
I'm doing it from a USB, maybe that is why. It will install MUT3 and run, however it sticks at MSDE. Do I put all the directories in one directory and let it do its thing. Right now I have the Copy master directory and the PRE1121-00 directories separate.
Old Sep 6, 2012 | 01:34 PM
  #236
omegis's Avatar
WOW! Love LC now. I emphasize MASHING the brake in before you go full throttle. When you go full throttle, you have to MASH that in too. Can't be easy with the brake or gas pedal. Your goal is to push that pedal through the floorboard or face the dreaded "SLOWDOWN" message.
I'll attach a log in a sec showing what SST temps did. You'll be in for a surprise.
Pretty sure I got whiplash.
UPDATE:
Started log right before using LC and stopped it shortly after. Need to turn down 1st gear boost now b/c I violated my redline and had to go manual.
Old Sep 6, 2012 | 07:49 PM
  #237
ra_guy's Avatar
I'm having the same problem... any solution?
Old Sep 6, 2012 | 09:27 PM
  #238
Snipingdude's Avatar
UPDATE:
Wow.. I wanna do this!!!!!!! What are the step by steps involved, ive read through the whole thread and all i remember is MUT III, some weird codes and dealerships not wanting to do it! post a video!
Old Sep 7, 2012 | 11:22 AM
  #239
masafina's Avatar
UPDATE:
you have s-sport in your car already?
Old Sep 7, 2012 | 11:47 AM
  #240
ra_guy's Avatar
got it, somehow wget missed some rather important files in the three /MSDE/SETUP/ directories... curious as to why, but eh...
various other files were missed, so check ur directories for empty folders...
Quick Reply: RA´s S-sport and launch. DONE
