Updated AWC software mapping...
a.k.a. Cold weather package reflash, AWC reflash, etc...
I got the AWC service required light, was worried that my ACD pump started failing...turned out it was a bad sensor relay and dealer replaced it and they updated the AWC software mapping for me....
the service required light went away but I started noticing that the tarmac/gravel/snow indication on the dashboard would flash every once in a while and when it flashes I would not able to switch modes....i searched and one guy said he got the same thing after the reflash and the indication flashes whenever the AWC is actively transferring power between the wheels...
anyone else see the same thing after the update? Thanks
Does this TSB tell you the details of the update? My Tarmac/Gravel/Snow indication flashes on my dashboard intermittently when I'm driving...I was asking if this is happening to the people who also got this update....
SERVICE CAMPAIGN BULLETIN
SUBJECT:
AWC ECU REPROGRAMMING FOR “SERVICE
REQUIRED” LIGHT ON - SERVICE CAMPAIGN
No: SC-09-002
DATE: September, 2009
MODEL: See below
CIRCULATE TO: [ ] GENERAL MANAGER [X] PARTS MANAGER [X] TECHNICIAN
[X] SERVICE ADVISOR [X] SERVICE MANAGER [X] WARRANTY PROCESSOR [ ] SALES MANAGER
PURPOSE
This reprogramming procedure will modify the All-Wheel-Control (AWC) ECU software to accurately
match the operations check of the AYC/ACD motor with current ambient conditions. Extremely cold
weather causes increased excessive load on the motor, which could result in damage to the motor. This
bulletin describes procedures to reprogram the AWC ECU with new software parameters to prevent this
condition.
AFFECTED VEHICLES
2008-2010 Lancer Evolution produced before 8/28/2009
2009-2010 Lancer Ralliart produced before 8/28/2009
2009-2010 Lancer Sportback Ralliart produced before 8/28/2009
If you want the full TSB in PDF format, send me a PM and I will email it to you.
SUBJECT:
No: SC-09-002
MODEL: See below
PURPOSE
condition.
AFFECTED VEHICLES
I have the same issue. They reflashed my ACD's computer yesterday because I had the ACD Service required Warning. Since then, the Tarmac thing keeps flashing very often and while it flashes, I can't switch the mode of operation of the ACD.
I didn't talk about it with the dealer yet.
scanned code afterwards was a C161F...meaning my ACD pump is pooched and not covered under the 5yr powertrain warranty
Trailbrake, I just tried sending you a PM asking if you could send me the full TSB in .pdf format, but the system says you're not able to receive PMs...... ?
Hi,
I got the update directly from the Dealer. My friend is the Head mechanic there and he asked mitsubishi directly and they told him its completely normal, it's a sign that the AWC is detecting torque changes and is transferring power. It's also double checking if the AC pump is not forcing for nothing. Go somewhere with Gravel, put it in gravel mode and try to spin or turn agressively and the Gravel will be flashing, same thing for snow. Don't worry about it.
Even with my car at 3.5 years old and at 64,000 km, my dealership contacted the District Service Manager and they ended up covering all parts cost (i.e. pump, fluids, and any other miscellaneous nuts and bolts) under goodwill, and I only had to pay around $500 in labour. So I'm pretty happy about that.
The pump must have been losing pressure for a while and gradually deteriorating the ACD/AYC functionality, and I must have gradually gotten used to it. Because now that the pump is pumping away again, it feels like a whole new car going through corners!
The system here did some odd things with my PM settings off and on for a while there, but that appears to be sorted now.
Try the following link for the PDF doc:
http://docs.google.com/fileview?id=0...NzFkNDcz&hl=en
If that fails, PM me your email address, and I'll send you a copy
I don't know how I missed this many months ago
404 Not Found homie.
bryanlo
10
Apr 9, 2014 10:40 PM
