stock map with pill
stock map with pill
Hey guys quick question. Ill be honest im in a tight spot right now so i didnt search a whole lot but im hoping someone will still give me an answer. I need to put the stock tune back on but i dont have the stock pill (its in the mail) can i do so? I have the following mods so far TBE, X FMIC, UR pipiing, works drop in filter. Thanks guys
I would say that if you DON'T GET INTO BOOST you should be okay. If you have a boost gauge just wach our boost and dont go over like 5lbs untill u get ur stock pill!!! That is just my 2 cents.
Stock tune with boostpill fitted? Nah. If someone else drives it and uses any decent throttle, high BWGDC percentages will quickly result in the excreta impacting the air circulation device.
Rich
Rich
