oil pan gasket leak back side of oil pan.
Looks like I got a leak in the gasket as well.
32k on the car, but i'm sure this started around 25k because I took my car to the dealer for the free oilchange\ check up and they accused me of putting the oil filter on loosely (oil all over the under pannel)
Ever since then there has always been oil all over the oil pan and underpannel but i figured it was just left over from the first incident as my oil level never seems to drop by checking the dip stick.
So last week I had the car up on jacks and decided to take off the panel and clean it all up so i can find a source. Checking it again last weekend it seems to be the gasket.
Would you guys take this to a dealer or fix it your self? I know its not a hard job to relpace the liquid gasket I'm just worried about the dealer @$#*ing somthing up since they should have checked this out the first time oil was all over the place instead of assuming it was somthing i did wrong.
Engine is stock and under warranty, I might just take it in and cross my fingers
Well Friday night I drained the oil and unbolted the oil pan (btw there isan oil pump bracket that also needs to be unbolted). After all the bolts wereoff the damn thing was stuck on there like glue, I finally went to the hardwarestore and picked up the thinnest metal stucco knife I could find. There areonly 2 or 3 areas you have room to work the knife in between the pan and theblock. While working the 3rd corner I heard it finally pop off..what a B$#^!! . So anyone preparing to take the pan off please invest in a thin, flexible, metal stucco knife. It seems to be the only safe way of getting the stuck pan off.
I could not see any indicator were oil would have leaked from but the stuccoknife probably destroyed the evidence anyway. Also the factory RTV was black instead of Grey like what is explained inthe Evo X threads. I scraped off thefactory RTV with so that it would not scratch the surfaces. Cleanedthe surfaces off and then applied to the pan only. I placed it on the block and hand tightened the bolts, after an hour I then torqued them to 98 in lb. I left it to dry for about 24 hours and filled it with oil.
So far no leaks!
Having the same issue toward the back part of the pan. I will check the bolts first before I take it back in. Service guy said it will be covered under warranty either way. 2011 Ralliart with under 41k on it. Never had issues until mods but no worries. It isn't leaking all over the place yet. I posted info on this in another thread.
WTB[Northwest]: AMS/Moroso Oil Pan
c4s3ys
Oct 7, 2017 04:56 PM
bnr34rb26dett
Apr 30, 2016 01:23 PM
