Engine codes
Engine codes
Hi Guys so today i was driving around and all is well, i go into a store come out and when i started my car my engine light was on. The car seemed to have issues staying running rpms drop low and it chugs. As im driving home i decided to punch it a bit and the car struggles and i only hit 10 psi but my afrs were still good. My obd2 scanner was stollen awhile back so i decided to give evoscan a shot and these were the error codes that came up
P02B8
P3101
P0200 Injector Circuit Malfunction
Checking for Stored CAN OBDII Diagnostic Codes...
Correct Header byte response returned.
3 Stored Diagnostic Trouble Codes Found...
P0131 Heated Oxygen Sensor (Front) Circuit Low Voltage
P0132 Heated Oxygen Sensor (Front) Circuit High Voltage
P0102 Mass Airflow Circuit Low Input
If these are the correct codes does anyone have any idea what my problem may be. I know its not recommended to use evoscan to check engine codes.
P02B8
P3101
