Car wouldn't start this morning
Old Sep 24, 2012, 03:10 PM
sirchumpalot's Avatar
I had this problem a couple months ago and the fix was changing the stock black relays with the newer OMRON relays. SSP has a package for them. The issue is when humidity and weather causes low voltage problems. There are threads in here for this, do a search for the FPR(Fuel Pump Relay)
Old Sep 25, 2012, 12:05 PM
Veronica's Avatar
I park on a steep incline every night - no issues starting. Changing the relay makes more sense.
Old Sep 25, 2012, 02:57 PM
Dbzguy's Avatar
Maybe for the OP. My issue is definitely not related to a bad fuel relay.
Old Oct 1, 2012, 06:38 AM
nmilsaps's Avatar
Ever since I posted that my car was doing fine, it started doing the same thing, just not as worse.
This weekend, took some advice and did some research on the Relay.
For $8 and excuse to visit SSP, figured it was worth a shot.
Did it work? No. But maybe I pleased the Mitsubishi gods in the meantime.
Stopped at Autozone, on my way home. Checked the battery, no charge. Bought a new battery, put that one in.
Car starts perfect again.
Thanks to all for their suggestions.
Old Oct 1, 2012, 06:53 AM
bossssman38's Avatar
Wish I saw this when it was first posted. I had the same issue a few years ago. My local autozone tried telling me I needed a new battery, went to the dealer to see what they said. Dealer reflashed the car (there was a recall or a fix of some sort) and it never happened again.
Old Oct 6, 2012, 03:40 AM
tencents's Avatar
i found this happened again.. i think both time its after i washed the car... it wouldn't start, turn off and it could started again.
Old Oct 6, 2012, 09:44 AM
crak's Avatar
Have you upgraded your relays. Its free from your dealership, since its a service bulletin issue.
http://www.sr20deracing.com/looneytu...002_relays.pdf
check the link out. Could be your A−24X.
I had an issue where my car would not start due to my starter relay, turned out it was corroded. Take a gander at it. What colour are your relays? Blue? black (made in japan)? The newest are the blue one or the black (made in italy) relays
Old Oct 7, 2012, 04:18 AM
It's nearly impossible to find the Italian relays now. Omron manufactures the same relay in USA now. The SSP package has these relays. In regards to the TSB, my dealer wanted me to pay $25 a relay. ******* stealership
Old Oct 7, 2012, 09:00 AM
crak's Avatar
seriously? mine did it for free...
mrm95
Sep 2, 2013 11:46 PM
crrowley12
Jun 23, 2011 09:10 AM
BlackOps
May 27, 2010 01:00 AM
fostytou
15
Dec 19, 2007 02:56 PM
Quick Reply: Car wouldn't start this morning
