Upgraded my UICP today.....
so today after work I installed my EVO X FMIC that I've been sitting on for weeks now along with an Agency Power UICP. I ordered a 2.5" diameter pipe (to match the stock EVO dimensions) but was sent a 3" accidentally. When i finally got it in place and bolted down I noticed that the hood didn't close all the way. After applying some careful pressure I was able to shut it but the question I have is....
has anyone fitted a 3' pipe to their RA and had this problem? I was thinking about grinding some of the metal off the inside of the hood (there's a part that protrudes toward the bottom quite a ways conveniently located over my UICP) but wanted some input before i tried anything
When I did mine, the black cover was pushed up a bit because of these little black tabs on the backside of it, near where the uicp bends. I just cut this out with a knife and it fit better, the black cover still sticks up a bit, but hood closes with no issue at all. If all fails, check, dbl check and triple check, there is always some wiggle room.
It lines up perfectly it just needs about 1/8" more clearance I can try bending the 12mm mounting bracket a little more but ther than that I'm gonna have to take some metal off the inside of the hood :/
NightHawk
Apr 7, 2014 09:31 PM
joeyhauser
Oct 10, 2012 07:30 PM
dfoote
Jan 11, 2012 12:58 AM
Splatzjackson
Dec 14, 2010 10:55 AM
