What downpipes are compatible with the RA?
Hey all,
Just doing some research and trying to find out which downpipes are compatible with the RA. This is for the Td04 turbo only (CBRD RAD lite).
I am particularly interested on the following Apex'i downpipe:
GT Downpipe, 2008-2011 Mitsubishi Lancer Evolution X
Part Number: 145-M006 GT Downpipe
Application: Year: 2008-2011
Make: Mitsubishi Model: Lancer Evolution X Chassis: CZ4A Engine: 4B11T
Specs: Piping Diameter: 70mm (2.76 in)
Full Stainless Steel
The Apex'i page does not give out much info, and I know there's quite a few downpipes which are interchangeable between the RA and the EvoX, hence my question. However if the above does not fit, what's everybody running? Any feedback/reviews would be welcome.
I answered your second question already. The down pipes that fit the RA (stock turbo and RAD turbo) are the down pipes that are specifically designed for the RA. The EvoX uses a different turbo (TD05) and the exhaust routing in that area of the car is slightly different. So, EvoX down pipes will not work with RA's that have stock or RAD turbos. In case you don't know, the RAD turbo uses the RA's stock turbo frame (TD04). So, exhaust components that fit the stock RA will fit a RA with a RAD turbo.
There are plenty of aftermarket downpipes available for the RA. Ultimate-Racing is one of the most popular. HKS makes one, but it isn't 3in (it's 2.5in IIRC).
With a little bit of effort, you could have found a sticky thread in the main 09+ Lancer Ralliart General that has an extensive list of aftermarket parts and manufacturers:
https://www.evolutionm.net/forums/09...-mod-list.html
You'd also have to check if you need RHD specific one for our aussie cars.
I know for the TD05 turbos we need a RHD specific 02/downpipe to clear the steering rack.
I'd get in touch with UR and tell them what your after and if they have a solution. The guys were pretty helpful when i got my stuff sorted.
are you talking about having the o2 housing as well? only one that i have come across is the ultimate racing one (3" long). not sure how the fitting would be with a rhd drive...
I was thinking more of something like this:
or
ie, the pipe from the dump to the cat only. Now, both these pipes fit both the EvoX and the RA, however there are quite a few pipes which only fit the EvoX. Is there a difference? I understand that the dump is different, bigger turbo, bigger exhaust outlet. However dump pipe back, they are both the same, aren't they?
or
Yeah I know, RHD/LHD pain the as$ frankly...
Just trying to source something o/s as local prices for parts are a bit of joke... ("Australia tax and all")
You CAN use certain EvoX downpipes on the RA while retaining the stock RA turbo. As long as you are shopping for the "short"-version downpipe that does not include the O2 housing, the EvoX downpipe WILL fit onto a RA.
As far as the APEXi pipe that you show, that is not an application specific photo since the "short" downpipe for the X and RA only have 2 bolts holding the pipe to the O2 housing. I would contact APEXi for more accurate information/photos to see if their downpipe includes the O2 portion and whether or not it replaces just the downpipe section, or the downpipe and cat sections (which it appears to do in that photo, if that were applicable to the X) or just browse one of the many other options available that are known functional products.
Also, a more helpful sticky would have been this (see post #2): https://www.evolutionm.net/forums/09...reference.html
JM Auto Racing
EvoX 'For Sale' External Engine / Power
992
Nov 28, 2022 11:33 AM
FS[Northeast]: APEX N1Damper ExV Coilovers
Freddy302
Mar 12, 2016 05:23 PM
RallySport Direct
Mar 12, 2016 11:41 AM
Jbevoxx
Sep 29, 2015 10:31 AM
