help with evo x turbo disassembly
Okay guys I have searched high and low this morning (since about 7:30) trying to find a diagram a how to or something to explain on how to fully disassemble the evolution x turbo. I looked here 9gl clubralliart and on Google and had no luck. So I am posting a new thread to hopefully find someone who has done or knows how to take the turbo apart the help would be greatly appreciated. If there is a thread and I missed it I apologize. I am mainly doing this as preventive maintenance with it (it only has 10,000 miles on it) but I just want to clean it and make sure there is no shaft play or anything else that's wrong that cant be seen when the turbo is assembled.
should be able to remove the nut holding the compressor on the shaft at this point to remove the compressor. check the threads closely to make sure it's not left handed before attempting to losen it.
shaft should pull out through the turbine side (with the turbine still attached) at this point. watch for spillage and possible bearings falling out though. I'm not sure how tight they fit into the cartridge.
Thanks man i got it all cleaned up and put back together and when i went to mike the things i realized all the numbers were worn off the shaft of it so no luck there but i will say for only 10,000 miles it was extremely nasty but it clean as its gonna get now turbines spin so much more freely too.
DaFastOne
Feb 21, 2012 01:33 PM
03lances
Lancer Aftermarket Forced Induction Tech
48
Jan 20, 2011 10:53 PM
StevenStarke
20
Jun 13, 2008 12:32 PM
