RA Build
RA Build
I have a 2010 GSR and have plans on selling it. What i was thinking about doing is buying a used RA and building it. Pulling the motor/tranny and getting them built, then installing a T4 frame turbo. If I relocate the battery, should all evo MR parts fit on the car? What i mean by parts is TBE, Intake, IC, IC piping, etc. Do evos and RA's have the same throttle body and Intake Manifold?
I dont care about the body/brakes/suspension/rims because i will be building those anyways thats why i kinda wanna start with a RA and save some money. Does the RA have different different A-arms than evos?
Does the RA have the same diffs, AYC, ACD, etc as the MR?
I want the SST and dont see buying an MR if i am going to be replacing all the "better" parts it has on it than the RA (ie. turbo, suspension, body parts, rims, all bolt-ons). I already had a Red maxed out using E85 on my GSR. It's either the Ralliart or a different platform.
If I relocate the battery, should all evo MR parts fit on the car? Mostly
What i mean by parts is TBE Downpipe, Yes; Catalyst-replacement pipe, Yes; Cat-back, No, Intake Probably, with an adapter, IC Yes, IC piping Upper, Yes; Lower, Probably, etc...
...Do evos and RA's have the same throttle body and Intake Manifold? Yes
I dont care about the body/brakes/suspension/rims because i will be building those anyways thats why i kinda wanna start with a RA and save some money. Does the RA have different different A-arms than evos? Yes
Does the RA have the same diffs No, AYC No, ACD Similar, but not sure if exactly the same, etc as the MR?
For the instances I say probably, it's not a matter of not knowing, but a fact that some are designed differently than others. So, depending on manufacturer, most will work, but some may not.
razorlab
5165
Aug 11, 2024 07:56 PM
Ibetchuwontdoit
Lancer Aftermarket Forced Induction Tech
Jun 11, 2015 01:44 AM
Jack Dempsey
13
May 4, 2013 12:40 AM
