Cobb 3port?
if you are running the v3 stage 2 map then i believe u need cobbs 3port installed. the maps are very sensitive to what cobb says is needed. i did a few 3rd gears pulls and seems to be at about 15-16psi.
I guess it depends on your situation. For me, I don't make a lot of money so getting parts sorta came over time. I like the access port because it allowed me to slowly mod and run bolt ons safely til I was ready for a custom tune. U will see the most gains with the stage 3 map. The only thing with the ap is that u must run exactly what the map says to run or u could be asking for problems. So if money's an issue, I think it's a good investment because u can mod from stage 1-3 when funds are available then after stage 3, u can get a custom map. Plus u can usually did the ap pretty cheap in the classifieds on this forum.
I have a ap running a stage 1 93 octane with Perrin foam filter ultimate racing cat back evo x bov way quicker responses no more turbo lag and better mpgs I was getting 23 highway now the highest I've had is 31 highway and like 23 city well worth it I love it you can feel the difference just with stage 1 but like what's been stated follow the mod list its sensitive I thought I could go stage 2 cause I throw a cat back on no dice lost boost almost like it went into a limp mode
I run the 3port and Stage 2 v2. Tried running Stage 2 v3 but max boost was 21 psi, on Stage 3 v2 I hit 25 psi and the car feels snappier in response and acceleration. I want to, at some point, bring it in to my local Cobb location to have them look that over and tell me why.
FS[Mid-Atlantic]: COBB 3 Port Boost Control Solenoid
bhaikalis
Apr 23, 2016 07:24 AM
