Bov
Bov
Hey!
New here, I just got a used 2012 Ralliart in mint condition and was thinking of doing some small mod's.. it's already got the cold air/ catback exhaust--typical mods-- and i was thinking of swapping the stock BOV with a "Go Fast Bits TMS Respons Blow Off Valve Kit".. i'm not looking to tune the car more just get the classic "pssst" sound.. I read a bit about recirculating the air etc but am curious if anyone out there could give some advice on whether or not to install it.. the benefits or dangers.. kind of a all around answer for a newbie to the rally/tuner scene..
Cheers!!
Cheers!!
Once you start modifying and increasing boost levels an upgraded BPV is recommended over the stock plastic part. The EvoX stock valve is a perfect upgrade and will work wonderfully on the RalliArt until you go big turbo.
The Evo valve does make a bit more noise than the RA plastic one, and will be even more noticeable with a cone-filter-style intake installed. I used to have an SSQV (recirculated) and am now using a stock EvoX valve because it is more consistent and offers greater driveability and it is really only slightly quieter than the HKS.
I recently got a used 09 Ralliart that the previous owner installed an Agency Power BOV on. It's set up for 50/50. I'm getting occasional "system too lean" error codes, and after troubleshooting other causes, I suspect the BOV. Our ECUs are expecting a closed-loop o2 system, after all.
I'm looking into getting the cap I need from AP to convert it to full recirculation (as the owner lost the one that came with it,) and if I can't do that, I'm considering replacing it with an OEM Evo X BPV instead. While I can't say anything decisively, I would suggest that a BOV you can convert between 50/50 and full recirc is probably the safest option.
Even if it is creating an actual rich condition, could it be fooling the o2 sensor into reporting a lean condition instead? Or am I just trying to blame a mod that I myself wouldn't have chosen?
