Questions about a mod list
I'm thinking of the following mods but I'm not sure what kind of power I could expect from them on an otherwise stock '14 RA running 91/93. Would this push 300whp or do you need to look at a turbo swap to get numbers like that? Additionally, I understand you shouldn't go past ~325 torque with the stock clutches but is that for the MR or the RA, or are they the same?
- K&N Drop-In Filter
- Evo X Stock FMIC + Piping
- Evo X Stock BOV
- AMS Boost Pill
- HFC + CBE (brand undecided)
- TCU Flash for S-Sport
I just made 338/302 last night on 93. I'm running tb exhaust, stock intercooler with aftermarket tubing, and ets intake only reason I did not make more is because of the bov actually. It leaks quite a bit so I would suggest getting a new bov it only holds about 23psi before it starts leaking and has to taper down pretty quickly to 19psi. I think if you got an actual intake though and a bov with the mods you have listed .you could for sure make around 300
Thanks for the tip on the stock Evo X BOV though, I thought they were good up to 30psi...
I'm using stock X FMIC and LICP and just got me a UICP from MAP. Heard good things about the Ultimate Racing pipes though.
For the downpipe I would love to find me a AMS Widemouth however I'm going to stick to using the X o2 housing and just pair it with the RA short downpipe and it should work til I can find one.
Deano_Engineer_
Aug 15, 2013 08:20 AM
