Rally Armor Mud Flaps On A Sportback?
I read on Rally Armor's website that the UR mud flaps don't fit on the Ralliart.
I called them up and it's specifically an issue with the back wheels. Apparently it doesn't fit correctly.
Has anyone fit these onto a sportback?
There's a local group buy for them and it's really cheap ($125 shipped).
I want to get these on ASAP but I just want to know what the fix is to get them to work.
I don't mind drilling new holes but I don't know if that works or not...
I have them on mine and they fit just fine....the only thing i did was on the back instead of using the bracket i just put the screw through the inner wheel well made the mud flaps sit more flush
After the first three easy fasteners and the flap is aligned... I drilled a new hole below and drilled a pilot hole throuh the plastic inner liner. I drilled the hole form the aft (looking forward)
I then just used the nut clip (supplied) and held it and used the screw that came with the kit - even easier/better
Other than that - great job ralliarmour! Everything else was easy/perfect
