Painted nose
#31
Do you have any pics of your car with the vinyl covered ring? Also, is the vinyl flat or glossy? I'm kinda picky and I think it would look wierd to me if the nose was flat/satin and the ring was glossy black. Thanks!
#34
#37
the vinyl is satin black vinyl from a sign shop.
you need to get a large piece. several inches wider than the ring ,at least.
cut out the shape of the ring , except real wide...
so it looks like you have a ring that is about four inches thick.
you will need a hair dryer to heat the vinyl slightly .
.......so it will conform to all of the curves.
#45
