AMS Single Exhaust & UICP
Yes it will. The stock FMIC has a rubber hose between the FMIC and the UICP.
Replace this with a reducer hose so the top is the size for the UICP and the lower end is the size for the FMIC. Plenty of people have done it.
BTW, post pics when you're done
This is where I get all my couplers: http://www.siliconeintakes.com/
do you think the AMS UICP will fit the UR FMIC??!?!?
if you're running an ra based intercooler you'll likely need a new silicone adapter for an evo based pipe. if you're running an evo based intercooler you'll likely need a new silicone adapter for a ra based pipe. if both parts are coming from an evo part-line, you'll fit just fine, except you'll need the silicone adapter for the ra licp then if you're keeping that one stock
