*My New Rota Grids Thanks WheelDude*
You used these? http://www.wheeldude.com/catalog/pro...roducts_id=709
WheelTek spacers, $10/each (3mm, 5mm,8mm, and 10mm)
I know you said you used a 5mm spacer, but do you think our lugs are long enough for a 10mm spacer? I'm guessing not. Also, did you use a hubcentric ring?
If you get some ra tails you can send them to me I can smoke them. I used a candy black spray paint I order online it's like 30 dollars a can. I took it off because they were too black since the insides are already black. I had no issues with cops I just dig the stock ra light look on WW.
Did you have to roll your fenders? I'm on Eibach Pro springs which have similar drop to the RRM's and looking to go with an 18x8 wheel w/ 225 tires. Any problems with rubbing due to suspension travel?
Thanks!
Thanks!
