New Oil cooler for Engine and tranny
so i design to make my own Oil cooler instead of buying and $500 one
so i spend about same amount but instead of get just one oil cooler i can get both for upgrade tranny one and add on engine one
for engine you will require to need this
also i add a fan behind the cooler
Any oil cooler would work (just not over 25 rows ) and if you want to know detail like fitting size I can't tell you that lol cuz I don't know it I went back and forward fitting shop to collect all of fittings but main thing you need for engine side will be
1 oil filter relocation kit ( you can purchase it of eBay)
2 oil cooler 25 rows (where ever you can buy what ever brand you want)
This are only main things you will need
why the filter adapter?
I have seen several using an adapter that goes on under the oil filter. I thought Ralliarts are already set up for a oil cooler like where the Evo X has its cooler lines ran. Is there a reason you would not run oil cooler lines to the OEM location? Just trying to see if there is a reason to use a oil filter adapter instead.
FS[Mid-Atlantic]: Invidia DP & TP, Perrin Intake, Hallman MBC
TBSE
13
Sep 16, 2014 01:16 PM
mangnok
May 26, 2014 08:35 PM
mangnok
For Sale - Part Outs
Mar 23, 2014 01:43 AM
mangnok
09+ Ralliart Show and Shine
Aug 24, 2012 08:48 AM
