Evo X Logging
Old May 31, 2009 | 11:57 PM
tephra's Avatar
Cool Evo X Logging - Working!!!
Hi Guys,
Graphical HOWTO here
UPDATE: Evoscan 2.6b14 (and now b15) have Mode23 support integrated - You only need this thread for the XML modifications you must do for Mode23 to work
I have spent a fair bit of time looking at the ECU code and I have found a very nice function that we didn't have access to in CT9A-land.
OBD-Mode23 allows you to request ANY memory address and the ECU will fetch the current stored value.
I have tested this on my car - and it *sorta works*.
Hamish is currently integrating this into EvoScan so we should have support very soon.
Now when I say it *sorta works* the ROM needs a slight modification before you can access Mode23.
My preference for logging is that the ROM should be stock and everything should just work - but given our woeful logging experience thus far we are running out of options.
One downside with Mode23 is that every RAM address is unique to a ROMID, so the RAM addresses for 53040010 will be different to 52680018 - This isn't too bad, it will just mean someone needs to post up the relevant addresses for the ROMID in question.
HOWTO:
1) Apply the XML changes to your EcuFlash definition file, if you don't know what ROMID you are dealing with just ask. Modifications to ROM's can cause catastrophic results if you don't know what your doing
2) Download the application zip - in it will be an .exe and a config.txt
3) Edit the config.txt to suit your ROMID - We will be posting up config.txt's for common ROMID's so you can probably just download that.
4) Run the application.
Notes:
1) It's only a console application - so there is no fancy GUI.
2) It records every 5th row to screen, but EVERY row to the log.csv file
3) There isn't much error checking, so don't put anything stupid into the config.txt
4) In the config.txt file the evaluation expression is in RPN notation.
Application:
V1.1 - Is an attachment down here....
you also need a config.txt - I have included the one from my car 53040010 ... ENSURE YOU CALL IT config.txt and put it in the same directory as the .exe.
XML's:
NOTE: The name in EcuFlash describes what changes you need to make (ie 0x05 -> 0x23). IF the CURRENT value doesn't match here STOP AND ASK!!!
52690019
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8aafd" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab02" scaling="Hex16"/>
53040007 -> 53040010
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f145" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8aa59" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8aa5e" scaling="Hex16"/>
52680015 -> 52680020
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
52360018
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f58d" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ada5" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8adaa" scaling="Hex16"/>
53600010
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7efbd" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8aa61" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8aa66" scaling="Hex16"/>
53050006 -> 53050009
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7f145" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8a9f1" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8a9f6" type="1D" scaling="Hex16"/>
54060007
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7efc1" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8aa7d" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8aa82" type="1D" scaling="Hex16"/>
54070007
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8aa69" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8aa6e" type="1D" scaling="Hex16"/>
55570005
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7f10b" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8ad5f" type="1D" scaling="Hex8"/>
<table name="DoMode 0x4D -> 0x5D" category="Misc" address="8ad66" type="1D" scaling="Hex16"/>
53610010
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7efb1" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8a919" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8a91e" type="1D" scaling="Hex16"/>
55580005 -> 55580006
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f10b" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ad4b" scaling="Hex8"/>
<table name="DoMode 0x4D -> 0x5D" category="Misc" type="1D" address="0x8ad52" scaling="Hex16"/>
55590006 -> 55590007
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7f107" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8ad43" type="1D" scaling="Hex8"/>
<table name="DoMode 0x4D -> 0x5D" category="Misc" address="8ad4a" type="1D" scaling="Hex16"/>
Cheers
Dave
File Type: zip
MV auto (Feb 7, 2019)
Old Jun 1, 2009 | 01:58 AM
Bob_tm's Avatar
I want to test Mode23 on EDM evo
Old Jun 1, 2009 | 02:42 AM
tephra's Avatar
Well if everyone is agreeable to the minor change (to enable Mode23) - I will post up some instructions on how to change your rom.
I tested it out tonight, and it works a treat - once I get a EvoScan version from Hamish which fully supports it then i'll post up a log or 3. I will also test the speed as well.
For the technically minded - I am overloading Mode0x05 which on CAN ECU's is unused. Mode05 seems to be a NULL subroutine anyways so I don't think its inuse.
Old Jun 1, 2009 | 06:47 AM
Hiboost's Avatar
Sounds like it is worth at least testing, assuming it doesn't break any critical operation of the ECU!
Old Jun 1, 2009 | 06:56 AM
tephra's Avatar
nah...
yeah im working on a basic logger right now...
Old Jun 1, 2009 | 08:38 AM
NMX's Avatar
NMX
Tephra, this sounds like it's definitely worth exploring. My only concern is with having to find the proper RAM addresses for each unique ROM ID. I have no ability to do this (I wish I could help out). Are there enough people (or are you willing ) to figure this out for the most popular ROMs out there? Or at least for 52680018
Also, do you know how far Hamish is from being able to log 2 byte CAN? Specifically, for boost and load? It seems we are pretty close on getting useful CAN-ID based logging as well, except for the 2 byte values. What's your opinion on this?
Old Jun 1, 2009 | 08:46 AM
pltek's Avatar
i just wanna log
Old Jun 1, 2009 | 03:57 PM
SiC's Avatar
SiC
I'm not familiar with this Mode23, what parameters can you log/recall with this?
Old Jun 1, 2009 | 05:09 PM
tephra's Avatar
NMX - well the good thing is there is still a MUT_TABLE, so once you find that then you can look up memory addresses REALLY easy.
but yes, the main ROMID's will be covered.
SiC - you can LOG memory address you like, you just send the memory address you want to log and the number of bytes and Mode23 returns it.
Old Jun 1, 2009 | 05:10 PM
SiC's Avatar
SiC
Nice, count me in
Old Jun 1, 2009 | 05:11 PM
Robevo RS's Avatar
guys , i know its off topic, but can some one find out how you can turn off the Airbag warning and a TPMS waring ??
Its killing me.
Thanks
Old Jun 1, 2009 | 11:16 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by tephra
Hi Guys,
What are peoples thoughts in regards to having to modify the ROM to allow Mode23?
Cheers
Dave
This is amazing find, maybe for the start it would be better to write a patch for retrieving values from MUT table as in CT9A, we have better understanding of what these values mean. But getting any memory value is really awesome.
Old Jun 1, 2009 | 11:51 PM
tephra's Avatar
Yeah I thought about doing that - but then it would be a complicated patch.
To enable MODE23 - it's 3 bytes worth of changes ... very very simple.
ok my program seems to be working well - here is a log I just took:
It's a STOCK 3rd gear pull - I got about 160rows of data during the pull - so HEAPS of data
edit - spelling + log upload (rename to csv)
edit2 - your seeing 2byte load, 2byte IPW, 2byte ADC_MAP, 1byte timingadv, 1byte knocksum, 1byte RPM
File Type: txt
Old Jun 1, 2009 | 11:59 PM
SiC's Avatar
SiC
That's awesome! So, how do I enable it
Old Jun 2, 2009 | 12:17 AM
tephra's Avatar
well let me finish the app first.. its real basic - but I need to make the memory addresses changeable by the user ...
also does anyone know if the scaling for the MAP sensor is the same as the JDM 3bar that is used as a replacement in CT9A? (ie 0.19374*x - 14.5)
Quick Reply: Evo X Logging
