The evolution of my Evo IX RS Wicked White
I previously own an 03 Evo 8 for two years before I sold it to get an AP1 S2000 to track. After 3 years with the s2k, my friend made me an offer on his Evo that I couldn't refuse and so the journey begins.
I purchase the car at the end of the year in 2010 when my friend decided to go in a different direction with a track car. I wasn't looking for a different car at the time because I was still enjoying the s2k but it was an offer that I couldn't pass. The car was in the shop getting worked on and the offer was to buy as is. After stopping by the shop to look at the car, I made the decision to buy the car knowing that I wouldn't be able to keep the s2k as a track car anymore which was a very hard decision to make. I was going to turn the s2k back to a street car and keep it as a daily driver but end up selling it in the end, no room to keep it around and i don't need two toy cars.
The car was dropped off at my house on a trailer with the engine, tranny and all other parts in the truck bed. I took my time over the winter and didn't rush anything. The hardest part was figuring out which bolts to use where since i didn't remove the engine, and it's been three years since I worked on a Evo.
2006 Evo IX RS with 15k miles
Thanks to TougeFactory and MotorsportsPerformanceGroup for supporting me on the way.
the business, stock evo 9 engine
parts
box of AMS goodies
parts
box of AMS goodies
start of the rebuild...
new Gates Racing timing and balance belt
Exedy lightweight flywheel with new Exedy oem clutch. new TRE stage 3 tranny ready go on.
engine on dolly ready to in
car hoist up with engine hoist to to get enough clearance for engine to go underneath
car is set back down on jack stand. engine is pulled up by engine hoist
heat wrapping down pipe
heat tape on lower IC pipes
heat tape on oil pan
IC, radiator and hoses are on
bleeding ACD
progress
fenders are on
bleeding ACD
progress
fenders are on
the car came with Odyssey light weight battery, but i wanted something with a little more cold crank amp. after looking around at some batteries, i decided to go with a Honda size batter (i still own 2 honda ). it was small enough to fit the short route upper IC pipes and has enough CC amp i wanted.
mock up
under hood clearance, about 1/4" from the heat insulator
welded and painted
bolted in
mock up
welded and painted
bolted in
coming from the s2k, i felt that the stock evo shifter was way too long even though i haven't even driven it yet. so i decide to try out a short shifter. got a cheap one on ebay to see if i like it.
cutting the oem shifter to get it out
the short shifter has two holes, the lower one is very close to oem. so i decided to drill another hole in between oem and very short.
short shifter in
short shifter in
the pillow ball on the Ohlins were worn out. the top hat on the Ohlins Vishnu/Gerrard spec uses Works camber plates which were rebadged Tein. I wasn't able to source new spherical bearings anywhere. I had a new set of Stance pillow ball and decided to give them try. turns out they were the exact same size.
removing the spherical bearings
Tein vs. Stance
rear top hat
Tein vs. Stance
rear top hat
i removed the APR rear diffuser because the car is going to be setup for NASA TTA which mean it would cost 2 mod points. If i was going to take points for a rear diffuser, I would make a custom one that's would be more effective than just reducing the parachute effect. that would be a future project
removing the dash for some top secret work
