Post Your systems
As I have a RS, I didn't want to add a lot of weight to the car, but still have a listenable system. I went with the following setup:
- Diamond Audio D362 speakers in the front doors
- Nakamichi CD-300 HU - a clear, detailed presentation and display colors that match the dash lights
- JBL GTS 100X amp that fits in the glove box
- RAAMmat Butyl-based sound deadening in the front doors to keep the sound inside the car (2 layers)
Alpine 9813 Single CD Head Unit XM READY
Front Speakers:
2 Rockford Fosgate P162S 6.5" Twin Drive Full-Range Speakers
Rear Speakers:
SUBS:
2 Rockford Fosgate T110D4 10" POWER T1 4-ohm DVC Subwoofers
AMP1 Highs:
Rockford Fosgate: P450.4 4-Channel Amplifier
AMP2 SUBS:
Rockford Fosgate: T3002 2-Channel Amplifier
Capacitor:
Rockford Fosgate: 1000 Watt Digital CAP
Interior LEDs in Trunk to Highlight the Rockford Fosgate System
Front Speakers:
Rear Speakers:
SUBS:
AMP1 Highs:
AMP2 SUBS:
Capacitor:
HEAD UNIT: Premier DEH-940MP
FRONT SPEAKERS: Polk MOMO MMC6500 (125 watts RMS each @ 4 ohms)
REAR SPEAKERS: Polk MOMO MMC650 (80 watts RMS each @ 4 ohms)
4-WAY AMP: MB Quart RAA4200 (100x4 watts RMS @ 4ohms, 200x4 watts RMS @ 2ohms)
SUBWOOFER: Alpine Type-X DVC SWX-1042D (1000 watts RMS / 3000 watts peak)
MONO AMP: MB Quart QAA1000 (1000x1 watts RMS @ 2 or 4 ohms)
Thank You!
Originally Posted by nashmage
very nice system redcloud its not too flashy but simple design at the same time i like that alot.
HU:Pioneer AVH-P6500dvd in dash dvd player
Speakers: MB Quart Q-series 6.5" components front and rear
Amp: Precision Power DCX-480 running components
2-Farad Capacitor
No sub, didn't want to add the weight and the MB Quarts hit pretty hard by themselves
2-Farad Capacitor
JBL Amp
I like your setup.
I checked the AMP at the JBL site, has not been made since 1998 according to their info.
Where did you get the AMP? Do you know of any good similar sized amps?
Seems like all of the current amps are huge and made extra large to look impressive, I would like something that I could stash like you did.
Any suggestions?
Thanks
Mitsuatb
Any suggestions?
Thanks
Mitsuatb
Originally Posted by mitsuatb
I like your setup.
http://imezak.stores.yahoo.net/gts100x.html
Shipping is a bit on the expensive side, but the overall cost is still very reasonable. Good luck.
Originally Posted by diegoalunan
what do u guys think of performance techniques 1200watt amp and 1000 12 " subs?... and pt's head unit with dvd and everyting?
This is the only amp I could find that fit into the glovebox. It's still a pretty tight fit. One of the guys on elitecaraudio.com pointed me in its direction:
Originally Posted by AlleyCat
Have you checked out the new Alpine amps? They are tiny and pack a big punch too.
That's still a touch too big, unless one is wiling to do a little cutting in the glovebox. The issue is in the height. Given the sloped surface inside the glovebox, a 6.5" height is the max, and that's without using an amp rack. With an amp rack, the amp has to be even shorter. It may be possible to fit a slightly taller amp if its connections are on the sides and if it's thinner than normal. I'm not sure such an animal exists.
