cam decision
Old Jul 6, 2007, 10:19 PM
boostin@27's Avatar
cam decision
what cams are better... hks or comp. i have an evo 8 by the way.
Old Jul 6, 2007, 10:48 PM
sparky's Avatar
I think you must have a IX, huh? If it was me, I'd go with the GSC's.
Old Jul 6, 2007, 11:26 PM
rediddy69's Avatar
gsc s1's
Old Jul 6, 2007, 11:35 PM
evoracingstar's Avatar
with my evo 9 got the cosworth love them
Old Jul 7, 2007, 01:26 AM
sonicnofadz's Avatar
I think the GSC s1's are making the best power for the 9's right now (on the stock turbo).
Old Jul 7, 2007, 09:19 AM
boostin@27's Avatar
i have an evo 8...
Old Jul 7, 2007, 09:30 AM
feldguy's Avatar
Thats a broad question....considering the die hards will insist you do a search, I will ask you a couple of questions...
What are your goals?
Budget?
Ideals (i.e., is a rough idle OK with you as long as you make as much power as possible, or you want the best all around setup?)
You need to determine what you are shooting for and what you are willing to live with to attain your goals, and also what supporting mods you have on the vehicle.
If its a bone stock car, you need to start somewhere else. Its obviously not stock if you're asking about cams, so I'll assume you're ready for it.
For highly modified cars, JUN cams seem to be the choice.
HKS are the staple units as they were some of the first used, but GSC has identical profiles for the HKS units IIRC.
Tomei's ProCams I havent seen used much....they have higher lift than some but there arent enough results that I can find, honestly.
Considering cost and effectiveness, determined by what you're looking for, GSC cams are dollar for dollar the best.
Old Jul 7, 2007, 09:35 AM
boostin@27's Avatar
well its a daily driver, so i want it to have a nice idle. but at the same time i want the most power and hp. i have to decide between either comp of hks cams.
Old Jul 7, 2007, 09:42 AM
mpevo8's Avatar
comp 280's are worth about 10-15 whp over the HKS as per turbotrix. a good tuner can tune out the idle for you. i did a lot of research.
https://www.evolutionm.net/forums/sh...d.php?t=258994
https://www.evolutionm.net/forums/sh...=comp+cams+280
https://www.evolutionm.net/forums/sh...d.php?t=253178
idle-http://media.putfile.com/280280-Comp-Cams-w-Fidanza-gears-set-at-20-idling-at-1200rpms-before-tune
Old Jul 7, 2007, 09:52 AM
boostin@27's Avatar
so what cams should i go with the hks 264 or the comp 272/272 cams for my 03 evo 8???? and what should i go with....264,272, or 280(doubt)
my following mods im running now are..
-20g turbo
-ams fmic
-injen uic piping with intake
-mr exhaust mani
-walbro fuel pump
-full tbe
-greddy profec bc
please let me know
thanks
Old Jul 7, 2007, 09:55 AM
Thegame's Avatar
I personally just went with the GSC S1's for the VIII. Read the comparison between HKS 272's and GSC s1's. It sold me.
Old Jul 7, 2007, 09:56 AM
boostin@27's Avatar
i have to chose between the comps and hks, i am getting them for an amazing deal!!! the gsc are way to expensive. i just want to know what ones will give me more power and be a better buy....
just read my last post
Old Jul 7, 2007, 09:58 AM
ROGERV's Avatar
get the Hks 272 over the Hks 264 .
Old Jul 7, 2007, 10:54 AM
boostin@27's Avatar
well im going with some comp 272/272, and im getting them for only $320 shipped!!!
Old Jul 9, 2007, 06:06 AM
tehforbes's Avatar
i got some hks 272's and <3 them ! i have just a base flash for nice and the idle is a litttle rough...but overall only thing i would change is for some 280's!~
Quick Reply: cam decision
