Testing out my new build today. 38psi 160mph!!! Aem log and more
First wanted to say thank you so much to English Racing and crew for the hard work and dedication you guys put in to help me get my car dialed in. Lucas and crew busted some **** today to keep her going
This is one hell of a ride! We are working really hard to get the suspension dialed in before we crank the boost up. The first few passes i had to re learn how to drive this car again 2698lbs and a hand brake plus all new build makes for one hell of a ride! What i can't get over guys this is 38psi and a 80.8mm turbo! It spools just fine. It really feels like it comes on much stronger and faster than my 42r.This could be due to the 10.1 compression and lighter weight also. When we get this dialed in i see 170mph plus as no problem.
The Extreme Turbo Systems Water to Air performed flawless and so did the ETS 45r kit with the Tial 1.00 housing. Temps hovered around 50-60 deg with very little ice.
The last run i let out 4th gear about 9200rpms @152mph and cruised thru at 160mph in the 1/4mile if i would had more ***** and held on longer i could have seen 165mph plus!. I shorted shifted 3rd thru 4th. Did 3rd gear at 9400 rpms where i should have shifted at 10,000rpms.
Here is the Time Slips and Aem logs
Here is our power band at 46psi
The track today with the amount of people took us almost 2 hrs to get one run in
Here is a quick video from today enjoy
http://www.youtube.com/watch?v=Dw_3r8vdW1I
Great Job Paul! Pretty amazing to run that mph and coasting through the lights and still run a 9.3 the first time out. AMAZING! Wish you guys the best of luck and will see ya in the 8's i no time!
Chris
Chris
