ECU Boost Control Duty Cycle info
Hi Guys,
In my search for improved boost control I came across some interesting information.
The code that controls the DutyCycle output only loops between 0 and 47.
Now for those of us that are good with maths, you will see that 100/48 = 2.08333...
So when converting out requested WGDC to actual BCS dutycycle we get the following:
73% WGDC = 35/48 = 73%
74% WGDC = 36/48 = 75%
75% WGDC = 36/48 = 75%
76% WGDC = 36/48 = 75%
So you can see that if you ask for 73% you will get 73%, but if you request 74% it will jump to 75%.
What this effectively means is we have a 2% resolution on WGDC, forget 0.5% its useless...
I hope this makes sense
Cheers
D.
Cheers
D.
Would it be beneficial to change the scaling in the EcuFlash XML to make it easier to understand, like having it go from 0 - 47? Just throwing it out there. This might be another reason why I am having some difficulty in tuning my boost, small increments of .5 or 1 might not change anything.
Well the good news I have created a patch to increase the resolution to 1%.
Now rather than just bumping up the counter to 100, I basically broke 100 into groups.
Initially I started with 4 groups of 25.
So for 73% WGDC you get the following:
73/4 = rounds to 18.
18*4 = 72, so 1 remainder
So for the first 3 loops I turn on the BCS 18 out 25 loops, for the last loop (ie the 4th) I turn on the BCS for 19 out of 25 loops.
So over 100loops I have 73 ON. Which of course is a 73% DutyCycle.
When I ran this code I found my boost dropped from 24psi to 19psi....
Now I have buggered off 4 loops of 25 and am now using 2 loops of 50.
It works fine.
MrFred and I think that there must be some latency involved in open/closing the BCS, which is why the same WGDC accounts for a lower psi. MrFred will be testing the latency of his BCS latter this week.
It works fine.
If it turns out to be a worthwhile patch then yes it will be integrated.
I was hoping more smaller loops would create smoother boost - but since we can't run more smaller loops then really the only advantage is increased resolution on the BCS DC...
Here is the part of code that tephra means.
But I am not sure that the solenoid is so accurate that this factor plays an important role.
Code:
ROM:0000AD54 mov.l @(h'1F4,pc), r4 ; [0000AF4C] = WG_Duty_Cycle ROM:0000AD56 mov.w @r4, r4 ROM:0000AD58 extu.w r4, r4 ROM:0000AD5A mov #h'30, r5 ; '0' Here is the 48 ROM:0000AD5C mov.w @(h'24,pc), r6 ; [0000AD84] = h'C8 dez 200 maximum internal Value of WGDC ROM:0000AD5E mov.l @(h'30,pc), r10 ; [0000AD90] = r4_mul_r5_div_r6_round ROM:0000AD60 jsr @r10 ; r4_mul_r5_div_r6_round ROM:0000AD62 nop ROM:0000AD64 mov r0, r1 ; r0= WG*0.24 (48/200) ROM:0000AD66 mov.l @(h'2A4,pc), r10 ; [0000B00C] = Backup_sr ROM:0000AD68 jsr @r10 ; Backup_sr ROM:0000AD6A nop ROM:0000AD6C extu.w r1, r1 ROM:0000AD6E mov.l @(h'1FC,pc), r10 ; [0000AF6C] = WGDC_Set_Counter ROM:0000AD70 mov.w @r10, r10 ROM:0000AD72 extu.w r10, r10 ROM:0000AD74 cmp/hi r10, r1 ROM:0000AD76 bf loc_AD94 ROM:0000AD78 mov.l @(h'1D4,pc), r10 ; [0000AF50] = PFDR ROM:0000AD7A mov.b @r10, r0 ROM:0000AD7C or #8, r0 ROM:0000AD7E mov.b r0, @r10
